tint?
xn
 Share
i need some help. is there any good tint places around brisbane? northside would be good. need an address and an idea how much it'll cost. wanting to tint both sides and back.
thanks in advance.
nexus? whereabouts is that? address? contact number? lol.
hmm.. im looking at black tint. tint-a-car quoted me for 195 (the midnight rage one lol)... u guys think its ok? hav an apointment nxt monday.
check if the $195 tint has a lifetime warranty on it man, that sounds pretty cheap could be good u never know. oh thats not meant to be nexus, but NOVUS, theres one in gravatt/ nathan area but i got mine down the coast. the tint i got is really dark black, the bad thing is its quite dark from the inside as well!
nismoman18, the 195 has a 5 yr warranty : what tint % did u get? legal limit is 35% isn't it? anything lower that would be really dark. how dark is yours? btw, is it the same % all around?
i got 20% cos 35% was just not dark enuff for me! its the same % all round, the last owner of my car had 5% on, i wish they left it on :( damn compliancing! maybe go to the one arkad suuggested that sounds like a good place. 5 year warranty means bubble and fade
nismoman.. ive seen 5% tint. a friend of mine had it on his car.. looks sweet!! but you have to roll the window down when your driving at night hehehe... im happy with my tint. they did i good job and the film they used actually looks quite dark...:(
ok.. thnx. anyway just got the car tinted.. and im happy with the results, except for one window, they didnt cut it properly.. so im b bringing it back to their shop tomorrow. thanks guys.
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
