Hi Fellas,
I just placed my Lenso D1Rs on my car (18x9 +32 rear and 18x8.5 +35 front), and to my suprise, the rear wheels differ.
I'll try to explain the best I can.
I fitted 265/35/18 tyres on the rear.
I put the rears on the car, and the right rear wheel stick further out of the guard than the rear left wheel. Both wheels are the same size and the tyres are the same....
It can either be one or more of the 3 things:
1) the tyres are f#$ked (both are Kumho KU31, maybe their was a manufaturing fault and 1 is wider than the other? Tyres pressure was the same);
2) Even though the rear rims are both 18x9 +32, maybe their was a manufacturing fault and one has a different offset or width?;
3) The diff needs adjustment? But I don't understand how this can be when it is independant and has independant shafts? Can each shaft be adjusted?
I've tried to contact the seller but no answer..... As you can imaging, I am pretty frustrated at the moment..
If you guys have any suggestions please do help me out!
Has anyone had a simular problem???
Cheers.
was this the case with the old wheels?
are you sure both rears are +32?
have you measured both to see if its true.
with cheaper end wheels, sometimes manufcaturing faults can cause them to be mismatched or have the incorrect stickers put on.
No it wasn't the case with the older wheels...
No I didnt measure them, these days you can't f#$king assume that what you buy is actually correct... F#$KING lenso!
Me and PaYbACk have the same problem. He's running 265's and I've got 245's on a wide rim and the left side sticks out about 5mm than the right.
We haven't had the time yet to sus out why and we've only had them on for a short while, but if you come up with an answer other than different offsets/rim width, let me know.
Yeah I'll let you know if I solve it....
Maybe an allignment will solve the problem...?
I dunno... It's killing me because now I can't lower my car until I fix this....
I think I found a way for someone to solve this problem.
Step 1) Place a long leveller vertically agaisnt the GUARD, making sure the buddle is level, then, get a ruler, and measure the distance from the hub, to the leveller (MUST ensure the leveller is perfectly level.
Repeat this for the other side. If the distance on both sides is equal, that means nothing is wrong with your car, however, if the distance is different, might have to take it to a wheels and suspension centre (i.e. pedders) to see what they can do.
Step two) If the distance from the hub to the guard is equal on both sides, place the leveller on the edge of the RIM (again, must make sure the leveller is perfectly VERTICAL), then measure the distance from the hub to the edge of the rim. Perform this for the other side (If this ends up the same distance aswell, then something MUST be wrong with your tyres (process of elimination, right?)
However, if they distance is different from the hub to the edge of the rim, the wheels are a different offset OR different width.
I will measure mine up tomorrow, and I'll get back you you fellas,
CHeers.
remove wheels, put what was the right rear on the left and what was the left rear on the right and re measure? Becasue if you swap the wheels over and the measurements don't change then it's the car and not the wheels.
99% chance your car is not straight, 1% that there is an issue with wheels or tyres
It turned out to be the tyres, I just measured it then.
1) The distance from the hub to the guard was the same on both sides
2) the distance from the hubto the rim was the sameon both sides.
Then, I laid a metal ruler on the rim and the tyre just to see the angle it buldges out, and the right buldged out alot more if you get what I mean. Then by eye, I could see that the right tyre buldged out ALOT more than the left tyre.
The rims are the same width as I measured them. Must be a tyre manufacturing fault, or it was put on incorrectly.
Problem solved.
Hope you fellas try the same thing, I am sure it will be one of those 3 things listed above.
Cheers
    • Hey, it's me! Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it. If this is not you, then sell it cheaper. It will sell at a certain price after all.
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
