Trying To Over Come - Over Boosting
Hi,
I've been having issues with over boosting when I reach 5K
so I spent half of today trying to fix my issue,
but alas, I didn't fix it, work perfectly up to 5K (7psi), then after that it climbs to 12psi by 5.5K
I'm not sure what I'm going to do, I didn't want to have a external wastegate,
I'll wait till I fit my intercooler and see what that does. (can't afford detonation)
oh, my setup
L24e N/A engine (no modifications at all)
RB30 injector
EDIS
Megasquirt
full 3 inch mandrel exhaust,
Nigel
How difficult was it to strip/reassemble your turbo?
Thinking about stripping mine (it's not making much boost at all, was running 12psi) thinking the wast gate might be playing up.
any pointers?
ps: sorry, not much help I know. Checked all your vacuum/pressure lines. Actuator spring might have given up?
Cheers Dan
taking the housings off is easy, 6 bolts i think. just centre punch mark where the were so they go back to the same rotation. i had same problem with my old cheap ass turbo so i drilled/filed out the waste gate hole. looks like you've already done that?
if ur actuator arm is an adjustable type can wind it out abit so theres less pressure holding the gate shut so when it extends will open the gate up pooftinth more
Edited by OUTATIME
any pointers?
Cheers Dan
As "OUTATIME" says, center punch so you can clock it the same when you put it back together, mine was very easy to pull apart. it was more trouble getting it out of the car (240K).
my issue is too much boost. on a N/A engine, I don't want to destroy piston ring lands.
as far as I can tell, the waste gate is open fully. it just doesn't have enough through put.
maybe when I'm running the intercooler, 12psi may not be a issue, will have to wait and see.
Nigel
To confirm your suspicion of insufficient flow, you can simply disconnect the actuator from the flap - this will cause the flap to freely open under exhaust pressure (you could also use some wire to hold it open at all times).
Take the car for a drive, and see if the boost still builds up too much.
I have seen such an issue with an old Hitachi turbo on an L26 - we had to fit an external gate to sort it.
On my mates ebay monsta turbo the wastegate did not open far enough for the gas to escape, so maybe try mounting the actuator on a different angle to give it more 'throw' in relation to opening the gate.
another idea is to get a custom dump made, with the screamer pipe coming out and rejoinging the exhaust after the firewall. this will help scavange gas out the gate too
my original testing before I opened the waste gate hole a little was,
I left the waste gate open (unconnected from the flapper arm),
PSI started to build a 4k, at 5k it hit 10psi, I lifted my foot when it hit 12psi,
I haven't disconnected the actuator this time to test, but I'm very sure it opens to the max, but I will test to make sure.
Nigel
sounds to me like your wastegate isnt big enough to flow the amount of gas that it needs, can you enlarge it anymore?? If not might have to go external gate
another solution..
read slowly
My T3/T4 has had the wategate 'hole' tapped/threaded, with a big metal 'plug' screwed in it (flush with both sides), then a new wastegate hole drilled in the rear that is bigger and to the side and down a bit. this was to clear the edge of the housing
a different gate installed to cover the hole was fitted too....
kinda getto spec, but its what was done, on the cheap too!
cheaper than external gate anyways
i'll get some pics later
  • 3 weeks later...
hey nigel any progress or updates????
Not really,
I've fitted my intercooler, but I need to hack my BOV, it's off a R32/33, I think it's opening by itself at about 7ish, so I'm going to do this mod http://www.thedodgegarage.com/turbo_bov_mod.html
I think I'm going to leave the wastegate as it is, so up to about 5K it'll run about 7-10 PSI, and over that it can over boost to about 12-15, I'm running rich and pulling spark at about 5K
Nigel
I did some data logging this mornining, IAT (intake air temp) maxed out at 30.7C with the intercooler, instead of the 60Cish it would be when doing a 1st, 2nd, 3rd flat out run, without the intercooler
I'm happy with it now, engine revs more freely now (I hit 6.55k RPM on my run today) compared to when it was N/A, it seemed to take a lot to get to 5.5K.
Now I need to get some wider wheels to help stop wheel spin.
and I modded my BOV, it appears to make difference.
Nigel
Edited by noddle
 Share
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
