Recently just installed the Turbosmart dual stage boost controller low boost set to 7psi and hi set to 10psi running stock turbo/intercooler.
While i thought running 7psi on low boost is stock, it seems to be much faster?? now boost comes on at 2,700rpm is this normal? i can feel more pull even on low while on high it goes ballastic.
Anyone else experienced similar?
Cheers All.
Are you complaining ???...or what?? :P
Are you relying on the stock boost gauge or do you have aftermarket
The model Turbosmart you have incorporates a wastegate anti creep gizmo which helps to bring on boost earlier
yeah with the turbosmart gear i have found that they actualy spike higher than what you set, then drop back to the setting.
so it prob feels faster because its hitting that boost level a little higher then dropping to the setting.
You'll also find that a lot of the bleed valves these days have some sort of anti wastegate creep built into them.
So by just installing one and leaving the boost stock, the boost will come in earlier and a bit harder.
When I was on the dyno, the operator was supprised to see my car had usable boost as low as 1800rpm in 4th gear !!
It's cause the bleed valve I'm using has an adjustable anti wastegate valve, as well as the normal bleed valve (it's a TurboXS HPBC).
J
Ben,
I'm not 100% clued up on it, but from reading the instructions it looks like it has two valves.
The first is a adjustable pressure valve so it will only pass air (that's funny :( ) when a certain amount of pressure has been reached. Then the second valve bleeds off air to hold the boost at a certain level.
So..... The way I've got mine set up is that the first valve is set to 10psi, so the first valve won't open until it see's 10psi, then the second valve bleeds off enough air to hold 12psi.
This way the wastegate (in theory) see's no pressure until 10psi - which leads to eariler spoolups :(
J
hey 51jay :( using my stock boost guage..will be investing in a aftermarket gauge in the near future. when it creeps up it sits just below the +7 mark on stock gauge. It use to run +3.5 1/2 way. How at roughly 5000rpm and above the car jerks alittle.. I have SAFC but haven't tuned it yet.. is this why the car jerks after 5000rpm + because not enough fuel pumping now that it is boosted to 10psi?
THanks for the feedback ppl. much appreciated.
The +7mark=about 1bar or 14.6psi, the halfway mark about 0.5bar or 7.3psi so 10.0psi would be about 3/4 mark. Boost level will be much easier to regulate with a properly graduated aftermarket guage. Sounds like your hitting up to around 12-13psi,....shouldn't hurt it.....enjoy the power.
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
