Everytime when I turn off engine and turn on again within 15mins, it will lose steering power and become heavy
If you wait the car for cooling down, may be 1 hour, it will not have problem at all. What is the problem?
and other question, I have changed the HICAS lock bar, but HICAS light turn on all the time, how to turn it off
Thank all for answer
https://www.sau.com.au/forums/topic/262167-steering-wheel-problem/
my 33 used to have a similar problem but now occasionally happens but goes away after about a minute - and my mechanic wasnt sure what the cause was but since it fixes itself now i haven't had a further look into it
and with the hicas light only way is to pull apart your dash and remove the light
Edited by Damit
You need to flush your power steering fluid. It is probably the cause for your heavy steering and your HICAS light coming on. It is not an expensive process and isn't a hard thing to do, but if in doubt, give Dan @ Elite Racing Developments a buzz and get him to do a service and power steering flush.
http://www.erd.com.au.
