the deposit is refundable anyway..
I don't see the damn problem.
this is NOT a backyard job.
this guy has 2 actual physical OUTLETS and they also supply many other stores with products.
it is a legitimate business.
not a "I've got a few things in my shed to sell" sort of deal.
so hurry up people.
I want my damn dials.
Guys,
I have just read a disturbing thread on the Skylines Downunder Forum regarding a group of 300zx owners odering dials from this company. Some of them waited up to 9 Months for their dials and some didn't even receive them.
Apparently they relfect during the day and make it very hard to see.
I am just going by what has been posted.
Please see this thread:
http://forums.skylinesdownunder.co.nz/show...7130#post247130
As for waiting 9 months...that must suck, but there may be more to the story, I am in no way associated with the company selling these, but...
If the 300ZX mob had the same arrangement as the SDU crowd then it was clearly stated that production would commence once positions had been filled... so the wait doesnt surprise me.
Especially when you look at the SDU post when something like 45 ppl said "yeh ill take a set" only never to be heard of again.
Anyway, its food for thought, what concerns me more then anything is the reflection during the day, i would imagine that it would have more to do with the plastic covering the fascia more then the dial face... but who knows, that could be a worry.
Ill stay put and see this thing thru...
sorry guys but I have had to cancel my order. wat these guys have said may have had a small bit to do with it, but I have spent soooo much in the last week like new turbo timer, wheels, tint....
I just can't afford it. so I have emailed the support team asking for my order to be cancelled and the money refunded to me. hope they are quik about it, but good luck guys
mark
I am now getting slightly worried. I have sent the email and got an auto reply. I thuoght I might call the shop to give a reason for cancelling the order.
NO ONE IS ANSWERING! I read what he other guys said, I hope this doesn't happen or I will be annoyed. have to wait for email response I suppose
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
