Hi guys, long time reader here first time poster
I've got a r32 gts25 sedan that i've sold my 20det setup (284rwhp if anyone cares) to build a RB30det, so far i've got a garret truck turbo, similar size to 3540, rb30e bottom end and r32 25de head, gtr valve springs, oil pump collar, just buying up the bits as i see them basically
I've also aquired a set of 26dett pistons, I've tried searching and haven't found a definite answer to if i can use them or how much work is required? i have a set of 30e pistons to which i'll use if the 26's arent any good, basically what i'm asking is  a) how hard are the 26 pistons to fit, and b) is it worth it?
thanks in advance guys. I'm sure i'll have many more questions as the build progresses
Cheers :P
https://www.sau.com.au/forums/topic/262171-rb30-gtr-pistons/
Pretty sure you have to use RB30 pistons as their pin heights etc are to suit RB30 rods & crank..
cheers for the reply, so i cant use 30 rods with 26 pistons? i havent had a chance to measure anything up yet, was trying to avoid wasting my time if people already knew the answers haha
might have to take them into work and whip up some drawings to see if its a suitable option,
Not sure on the exact differences, I'm using RB30 spec forged pistons. You might find that with 26 pistons on 30 rods on a 30 crank that you could be smashing pistons into valves.. need an experienced RB builder to answer that :P
cheers guys, turns out one of them is poked anyway so ill prob just stick with the 30 pistons, on the subject of 30 pistons, i've got a set that i had ultrasonically cleaned, when they came back they had lots of pitting in the top of the piston, im assuming its just bad casting/ has anyone else had a set that were the same? i tried to take a pic but it wont pick up the detail- aka budget camera
That pitting is probably from detonation..
I was hoping that wasn't the case but had my suspicions, picking up another motor tomorrow hopefully the pistons in that one are better, first motor had a bent crank (god knows how) so i had to buy a whole new motor to get a new crank, what a mission just to get more power!
Bent cranks are quite common in i6 engines.. just make sure you get all your clearances checked and machine appropriately.
it had about 0.3 bend in it, decided to try another as its cheaper to get a new one than grind, bit of a gamble to but its a low k's engine so should be ok
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
