  • Replies 161
Posted Images
Interesting to read the V8 take on the race :(
Funny how there was no mention of this GTR being a 20 year old, mostly driveway-built 206KW *nugget* against a couple of workshop backed 300KW+ almost brand spanking new taxis :nyaanyaa:
Now while we've been having a little bit of cheeky fun with this thread I should point out that there is always brilliant, skilled racing in the CTC category, regardless of the badge on the car.
Should also mention that most of the commodore guys seemed genuinely pleased to see Duncan FINALLY finish a race, and finish it well.
(and yes, I am still in trouble for posting that pic) :(
bloody commodores are already wide enough. at least we can rely on wakie not being hot and dry. I'm loooking forward too it but I would rather a couple of sprint races than one enduro really.
yeah the mount I got was from RR as well. they are cheaper on ebay though. it is attached to the rear passenger window, gives good in cabin view for my use in reviewing laps but not great for mounting it maxmising external view thru the windscreen. the best mount I've had for that is from the passenger side roof at the a pillar - these cameras have very wide angle heads so you need to mount them right forward. this is from that spot
http://www.hgeconsulting.com.au/bump.wmv
Thanks Duncan. Is yours the suction mount, or the window mount version.
These seem like a pretty cheap option: http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...=tab%3DWatching
yeah mate its the same one in that link. I just paid 3x for it :( It holds a light weight like a camera head easily and firmly. not sure how it would go holding a whole camera though, and as I said window is not necessarily the best place for in cabin shots.
I want to try mounting it off my cage as I had a cage mount put on for my Handycam... waste of money that was! :(
But I also want to try mounting it off the window and where you mentioned near the A pillar also. I just wasn't sure whether to get one like the above, or the 'Ultra Clamp' type from Race Recall http://racerecall.com/mounts__cases.html Can you tell me how the POV head mounts to the screw type fitting on the ebay clamp I listed? I'm not the sharpest tool in the shed :(
Dan came up with a pretty good setup for recording track time on my car. Spy pen, zip tie + numberplate ftw. Might not be applicable to race-style events as the camera might get crushed if you were to give the car in front a Duncan-style love tap, but for time attack where you dont have to worry about contact, it's pretty secure.
http://www.erd.com.au/ERDR33GTR.wmv
the spy pen was like $80 and can do over 5 hours of continuous recording. Plugs straight into pc/laptop and the files are already in avi or wmv format.
some proof this is a proper driveway built car!
the shelter came out when it started pissing down this arvo :P
D is still out in it getting the poor old girl ready for the 1-hour race at Wakie this weekend (and I'm guessing still cursing we won't have the 3 car + hoist shed built until June at least)
Oh yea,,,forgot about that little oversight. I'm at Oran Park this weekend,,,so Duncan needs help. 3 heads actually,,,1 to hold the car (no touching) 1 on the jack (also the wheel swapper) and 1 changing the wheel.
Ha Ha I could use some help too,,,but Duncans racing is a lot harder than mine.
Neil.
Spotted today :D
Hey Duncan,I'm thinking about becoming a paid up member of the club for amongst other benefits being able to go to race tracks on track days and give my GTR 33 a run,just wondering if you can tell me what's required of me before I can race on the track or even do solo laps to avoid hitting or being hit,as I don't want to damage my baby just want to have some fun legally??Cheers Grey Pearl.
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
