18X7.5 ENKEI 5 SPOKE RIMS + HANKOOK TYRES
+38 OFFSET 5/114.3
225/40R18 TYRES G/C
$1600
18X8 18X9 SPEEDY CHEETAH + FEDRAL TYRES
18X8 + 32 OFFSET
18X9 +36 OFFSET
BLACK FACE, GOOD DISH, CLEARS 4 POT BRAKES
225/40R18
255/35R18
FEDERAL SS595 TYRES G/C
$1100
### WILL SWAP BOTH 18' SETS FOR GOOD JDM GTR OFFSET 17 - 18 - 19 RIMS AND TYRES ###
S14 GANADOR MIRRORS
GENUINE ELECTRIC, PAINTED BLACK
$450
S14 MANUAL KIT
S14 ABS TAILSHAFT
S14 SPEEDO SENSOR
S14 BRAKE AND CLUTCH PEDALS
S14 CLUTCH MASTER CYL, LINES & DAMPER, SLAVE CYL.
S14 FLYWHEEL, CLUTCH, FORK AND THROW OUT.
S14 MANUAL X-MEMBER & MOUNT
NO GEARBOX, CONSOLE SURROUND OR BOOT
$400
SR20 5 SPEED MANUAL GEARBOX:
NEEDS REPAIR!
2ND GEAR SYNCRO CRUNCHES ON DOWNSHIFT
NEW BEARINGS AND FRONT HOUSING FITTED 12 MTHS AGO
$300
S14 - R33 REAR COIL OVERS:
HKS/KAWASKI, 30 WAY DAMPER, GAS PRELOAD
APPROX 6KG SPRINGS, HEIGHT SEIZED
$250
MORE PHOTOS SOON
GOLD COAST
SAM 0423 648 114
Edited by RED513
https://www.sau.com.au/forums/topic/262194-sparrows-garage-sale/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
