  • Replies 219
Aiming to get back to the dyno the weekend (or Friday) after the easter long weekend.
Guilt, will you be free sometime around then?
I want to wind the boost up from 17PSi to 19PSi also. Hopefully then with a bit more boost and the hi flow cat, it will crank out ~300AWKW.
It will be interesting to get a power run done on a Sydney Dyno down the track to compare results.
How did the dyno run go Bakes?
Due to Paul having to go to Qld for work I took the car to Sydney to get it final tuned. Car got tuned today by Scott at Insight Motorsports. Ive spoken to him over the phone, it made 396 Horsepower (295Kw) at all 4 wheels at 1.3 Bar.
This is with my 19 inch Volks on also so with stock wheels it will pull 310-315 All wheel Kw. Im looking forward to driving the mofo.
Ill post up graphs when I get them.
Why would it make more power at the wheels with the 18's ?
of all people i thought you would know this dude... unless you use a hub dyno.. the size of the wheels and friction properties of the tyres will affect the power output on any particular dyno.. high reading or low reading.. his volks have a rolling diameter of 675mm while the original gtr wheels are 654mm, so the original wheels will give a higher speed reading and slightly higher power reading. the big wheels will give a higher torque reading and less speed.. it doesnt matter anyway as the dyno was just used to tune it.. scott @ insight said it has got more to offer and its a very safe tune for day to day driving.. and its been tuned for maximum low down response... not top top end power.
regardless of power readings and dynos and crap thats gone on and what anyone thinks.. this car now hauls. it has fantastic driveablity, excellent fuel economy, and power to boot.. for the amount of punting bakes does.. the money has been spent, the parts are fitted, and the result at the end are what matters, it should keep him happy for a while..
simon, if your not content with anything about bakes gtr, feel free to line your r31 up anytime you like (or your mates mp3 player) .. until then.. let him enjoy his car stop worrying about what you could have done for him..
Car made 400HP at 4 wheels but was pulled back a bit on final tune to keep everything nice and safe (stock motor) Not running crazy boost either. (only ~1.2/1.3 Bar)
The tune is fantastic, runs so smooth. Tuned for cold start also, Im very happy with it. Ive found no need to give it more than 70% throttle yet either, she goes pretty good ;)
Here is my performance mod list:
* HKS Front pipe, HKS rear pipe with Hi Power Muffler, Hi flow cat
* Garrett 2860R-5 Turbos
* HKS SPL full piping kit with HKS super power flow pods
* Nismo Fuel Pump
* Turbosmart fuel regulator with pressure gauge
* Hypertune Billet fuel rail
* Siemens 610cc Injectors
* OS Giken Cam gears
* Nismo twin plate clutch
* Vipec V44 ECU
* Tech Edge Wideband AFR controller
* HKS EVC6
Tune results at different boost settings on Insight Motorsports Dyno, ALL WHEEL HORSEPOWER: (19 inch volks on)
Now for those interested I had some fun with excel to compare my results from where my car was stock except for exhaust to where the car is now:
Notes: Above dyno graph is in All Wheel Hosepower, the graph below I made is in All Wheel Kw
: Blue line was done on IS Motor Racing Dyno with stock wheels/tyres
: Yellow and red lines are on Insight Motorsports Dyno with 19 inch wheels
My biggest loss in response is ~ the 100Kw mark with a loss of ~550/600 RPM. The -5s catch up ~ the 4400 RPM mark
Would be interesting to do another power run now on the IS Motor Racing Dyno.
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
