  • Replies 219
You might be right Moei. Ill have to wait a couple of weeks to find out for sure when I get a chance to get back to the dyno.
The car is driving great on the road, a wall of power from 4K Rpm all the way through to 8K Rpm. Theres just nowhere for me to go flat out through 3rd gear and on, Id be just a little over the speed limit :devil:
the clincher in my opinion is the Nismo gal. radiator guide plate. Whats the Nissan part number for that one Bakes?
would have been nice for Wayne to let us have a quick run on the rollers today after the Toyota club had finished.
Dave tells me the cat that was fitted represented a significant (up to 40%) restriction in the system. He owns an exhaust shop so his knowledge is reasonably accurate.
The numbers up to where the power starts to nose-over are all excellent for the set-up, and we by no means pushed the car hard....but there is something stopping it making more power, winding more timing, less fuel or more boost to try and push power figures is pointless at this stage. Its a method of just trying and testing a few ideas when Bakes comes back from working interstate to get the power where it should be at this level of tuning. With the wheels fitted to the car and the level of tuning the car has now i estimate the power is down about 40-50KW of where it should be...yes a restrictive cat can rob you of that.
Edited by DiRTgarage
Paul, Im working as a contractor for Nismo in relation to the Gal Nismo radiator gap plate.
I can custom make them and sell them for $450 if anyones interested, lol :(
OK part number is 024U-225371 or 024U-BAKES1...lol
I hope you have arranged with Christian (Prank) to operate as a trader on this site.
one vote for fuel pump
lol
a lack of fuel would have shown up on the dyno...we had to take fuel out of it.
its holding its afr's dead flat to redline.
ive had my car not make anymore than 10psi boost due to a stuffed cat and soon as it was unbolted it went back up to 18psi, thats with a 3' magic cat too, blocked/restrictive cats can kill power bigtime, definately capable of gaining 60kw+ if the cat is blocked or just ultra restrictive.
Hey Bakes hopefully all gets sorted so you can get that magical 300+ mark. Ive just replaced my titanium exhaust with the Varex system and im happy with the outcome. I was quite surprised how much better it ran after installing a high flow cat. Though i miss the loud sound i had, the car still sounds great and when i push the remote its full on stealth mode (no cam burps)..
Cheers for the comments guys!
Great info Unique1, Thanks. Definately could have been my problem then. We will see.
Fatz, I have Nismo fuel pump.
Huy, Thanks, you might well change your cat to after we see my next dyno result in a couple of weeks.
did u bright sparks think of dropping the exhaust after the front pipe to see the effect?
yes we did think about this, however it was not possible to do because we were running out of time and it was 10pm at night by the time we hit the power brick wall and running the car with no exhaust would have been bad.
very nice car bakes.
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
