Hay
I just had a dyno done to me car it is putting 183rwks i was advised by someone that i should upgrade the oil pump, he reckons that that kind of power i should upgrade i want to put a boost T on aswell to push it to 200rwks, is this true about the oil pump
cheers
https://www.sau.com.au/forums/topic/262212-oil-pump/
I'm only pushing 170RWKW's in my RB20 and I just did a big end bearing up at wakefield due to oil starvation. In saying that I was bouncing of 7500 rev limiter (maybe not bouncing but it was a drift day) and had the car being thrown around fairly violently.
So unless you are belting your car side to side, and redlining it, you don't have much to worry about, But i would do it if you were building your motor :)
https://www.sau.com.au/forums/topic/262212-oil-pump/#findComment-4492452
Yes - on the proviso you have done the rest of the mods.
183 rwkw in a GTS-t is very good so I suspect you have a few mods already. FMIC, Zorst, Turbs, Puter etc....If you want to push 200rwkws - safe not sorry. Spend now and save later. Would you risk an engine rebuild?
https://www.sau.com.au/forums/topic/262212-oil-pump/#findComment-4498352
Its an 94 r33 gtst This is My first nissan skyline so i am not sure on what mods i need to do so it does not blow my engine and to get more power
Ok, as its your first skyline ill be very blunt;
-Changing oil pumps in a GTST is a waste of time with that power level, or if its working fine
-You will break the oil pump if you bounce off the redline time and time again
-Always warm up before using more than 30% throttle on cold start
-Always cool down (fit a turbo timer if you're a leadfoot)
-Before adding power, sort out suspension and a short shifter for the gearbox
-Once you've got it sorted suspension wise look for more power
Powerwise;
-FMIC (forum sponsors)
-EBC (forum sponsors)
-HKS GTRS kit (forum sponsors)
-ECU, ideally one that uses MAP vs TPS for mapping (forum sponsors)
-Quality exhaust including highflow cat, good dump pipe (forum sponsors)
EDIT: If you need any further clarification, call a few workshops and get quotes for "just a new oil pump fitted" :laugh:
https://www.sau.com.au/forums/topic/262212-oil-pump/#findComment-4502476
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
    • The thing is, once the content has been tagged we can chop and change the end result as much as we want. Its identifying the content in the first place that needs to be done regardless of the final outcome.
    • Sorry @GTSBoy I thought I'd replied here. There's a new BIG version of invision coming out soon, it might be worth waiting until that happens as it contains a lot of improved functionality for tags. My suggestion would be to add a top level page (not thread) with some info on it and then link to sub pages for various topics. We could even just start really simple with 2 or 3 pages underneath it. Those pages could just have a view (like a pre configured search result) of the tags we choose to put on it. We could have some background or an intro on each of these pages. My only issue is that while admins and mods can update the existing content to contain the tags we want, new posts can have whatever tags the author wants. That said, the reason our tags are so messy is because of that, so maybe we restrict tagging to admins/mods in edits.
