  • Replies 144
JT
nah, got the crappy black auto with the RR panel losing paint and sanded back bonnet.
My red manual is a beast with 3 piece wheels and a custom rear wing. Just getting back on the road now to start club racing again but got my roadworthy and the discs are undersize so time for a new set. DBA will cost 1K for all 4 from Autospeed but I'm told by a guy in Epping he can get slots for under $500 (not DBA). I'll post when I find out.
Also got a green soarer and black laser lynx. give us a wave and feel free to stop and chat. :P
____________________________________________________
OK this is the price update. Slotted fronts ar $220 each, plain rears are $190 for the pair (cause they don't work too hard, even on track) so @ $640 I'm well ahead but I will have to get the heat sensitive paint out and bed them in properly cause I won't get enough driving in before Sandown next weekend. Always worth doing well anyway. The procedure is on the DBA website.
  • 3 weeks later...
funkymonkey,
yeah, the street directly after the supermarket is called Gladstone st.
your mates house is on the corner of edgars rd & gladstone st, and it has a carpark next door on the other corner, correct?
you might see me drive past sometimes in a grey VN HSV SV3800 with personal plates.
yeah that's the one... hehe wave the next time u go by :( we're usually there on sunday arvo's doin sum sorta shit (workin on dirt bikes, cars or jus havin a drink)
  • 6 months later...
don't cruise. but i go shopping, live and go to uni around mill park - bundoora - greensborough.
LOTS of skylines around this area owned by ex VL drivers with attitude I must say...
Well yeah, what I mean by cruise is does anyone actually drive around this area that owns a Skyline. Bad choice of words I suppose :(
Still see ALOT of commodore drivers getting around here, I suppose this area has always been a tad bogan-ish..
[Edit: Shit, I just realised how old this topic was. Sorry for the post dig guys, just this came up in my search of the "Watsonia".]
  • 1 month later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
