  • Replies 144
Originally posted by RS500
dude,
there definitely were with plenty of action, but they must've been the days when u were still playing with crayons   ;-)
I guess so, Were they part of the "Other Team"? You know when they talk of Touring car racing of early last decade they use the phrase,
"There were the Skylines and then there was everyone else"
Haha, thats pretty funny. I've lived in Melbourne for all of my 26 years and not once have I been to Thomastown, Lalor,Epping or Mill Park. Like I said, I have no idea where any of them even are.
But yeah, I had no idea about anything to do with VLs. too young I spose
I caught the car bug from an Alpina C2 BMW. Then when I discovered Skylines that was it for me. There were suddenly no other cars which interested me. Except perhaps the Supra.
and if all else fails its a good old Exa, or a rajab tuned sumfinorother.
But seriously the number of worked cars to male ratio is exceptionally high.
For example, we're always there on sundays near edgars rd quix (nex to tha supamarket) workin on cars n shit, and every car that goes by that's dun up slows down hasa look, sometimes has a chat, and sometimes u get the occasional good lookin chick walk by and have a chat too... is all good fun.
The scene is well n turely there in thomo/epping... it just needs to get organised... like a Northsyeeeeed SAU VIC :D
yeah, there are JETs driving around everywhere these days.
but my point is that when the VLs were dominating the streets, there was plenty of drag, thrashing & burnout action back then but now everyone only likes to look good while driving in their jap import with big 5" chrome exhaust tip ;-)
Funky,
are u talking about Gladstone st? if so, i always drive past when going home from Bi-Lo.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
