  • Replies 144
JT
nah, got the crappy black auto with the RR panel losing paint and sanded back bonnet.
My red manual is a beast with 3 piece wheels and a custom rear wing. Just getting back on the road now to start club racing again but got my roadworthy and the discs are undersize so time for a new set. DBA will cost 1K for all 4 from Autospeed but I'm told by a guy in Epping he can get slots for under $500 (not DBA). I'll post when I find out.
Also got a green soarer and black laser lynx. give us a wave and feel free to stop and chat. :P
____________________________________________________
OK this is the price update. Slotted fronts ar $220 each, plain rears are $190 for the pair (cause they don't work too hard, even on track) so @ $640 I'm well ahead but I will have to get the heat sensitive paint out and bed them in properly cause I won't get enough driving in before Sandown next weekend. Always worth doing well anyway. The procedure is on the DBA website.
  • 3 weeks later...
funkymonkey,
yeah, the street directly after the supermarket is called Gladstone st.
your mates house is on the corner of edgars rd & gladstone st, and it has a carpark next door on the other corner, correct?
you might see me drive past sometimes in a grey VN HSV SV3800 with personal plates.
yeah that's the one... hehe wave the next time u go by :( we're usually there on sunday arvo's doin sum sorta shit (workin on dirt bikes, cars or jus havin a drink)
  • 6 months later...
don't cruise. but i go shopping, live and go to uni around mill park - bundoora - greensborough.
LOTS of skylines around this area owned by ex VL drivers with attitude I must say...
Well yeah, what I mean by cruise is does anyone actually drive around this area that owns a Skyline. Bad choice of words I suppose :(
Still see ALOT of commodore drivers getting around here, I suppose this area has always been a tad bogan-ish..
[Edit: Shit, I just realised how old this topic was. Sorry for the post dig guys, just this came up in my search of the "Watsonia".]
  • 1 month later...
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
