Hey Guys,
I'm considering in painting my Grille in the same colour as my Car. Colour Code KH3 Super Black.
Now I have he paint @ home in a Spray Can from AutoOne.
Is there anything I should do to get it looking near perfect.
I've rubbed it down with 1000grit Wet/Dry.
-Should I prime it?
-Clearcoat needed?
-Should i rub down with 2000grit between each coats?
Cheers
https://www.sau.com.au/forums/topic/262237-painters-please-helptips-please/
I'm not a painter but I work with them all day. It depends on the paint, but I would say yes, a compatible PLASTIC PRIMER would be a good bet, and plenty of wax and grease remover. Clearcoat will make it last longer if there is no hardener in the basecoat. Ask the people you bought the paint from, if they don't know, don't buy paint from them.
as said before, plastic primer would be best then wax & grease remover (also known as prepsol) If the paint is metallic it WILL need a clear coat otherwise it will have a matt finish, If it's a solid black i would think the can of paint you have is a can of 2 pac paint which will leave it with a gloss finish but like all 2 pac paints will fade quite abit over time
OK. Thanks guys.
What i've done is painted some spare plastic i found lying around the house.
Prepped it, primed it 2 coats.
Gonna Paint it tomorrow and see what the results are like, ie: if it's glossy or not?
Are all clear coats the same?. How many coats of clear should i use if so?.
Thanks Again.
RJ
  • 3 weeks later...
Hey Guys,
-Should I prime it?
-Clearcoat needed?
Cheers
spraycan.. should be ok for the colour but use a spraygun for clear
primer is an option coz it gives better adhesion
and use plastic primer and prepsol
as for the rubdown with 2000 between each coat dont have to, unless ur buffing it!
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
