I HAVE MANY OTHER PARTS JUST PM ME IF U NEED SOMETHING
LOCATION - NORTH BRISBANE
ALSO HAVE RB20 ENGINE
DIFF
GEAR BOX
DRIVE TRAIN
DAMAGED SHELL
Python Alarm System Bought Brand new For $700 Will Sell For $200 - INSURANCE COMPANY COVERED.
GTS-T Bonnet - Slightly Preped for Paint $80
Steering Wheel - $20
Boot With Wing - $80
Dash Cluster - $50
Cluster Surround $30
Console Surround $20
Console Surround 2 - $20
FMIC unsure of size but i think its brand new - $80
Dash Complete Minus 2 vents... i know everyone is missing vents - $80
Drivers and Passenger Door Cards - $25 each or both for $40
Drivers and Passenger Side Gaurds - $100ea (high demand)
Front Seats $50 each or both for $80
Tail Lights - $80
Indicator Arm - ppl seem to break this alot. $45
Passenger Window Switch - this breaks alot for ppl but this one is fine. $40
Air Pod nfi - $20?
Rear Qaurter Windows Tinted hardcore - $150 each or both for $250 RARE
BN Rear Bar Fiberglass small crack - $80
CRACK
Rear Seats (2) - $60
Rear Windscreeen - $120
GTS-T Stock Suspension - $100
Edited by NIS532
https://www.sau.com.au/forums/topic/262240-r32-parts/
can i get just the rear light covers?
sent to mackay qld
sorry i want to sell lights as complete.
i'll take the cluster surround.
PM sent
PM Replyed
no worries can you find me a price for postage of the steering wheel to postcode ACT 2913
the rearbar may be too expensive to post
yer sure no problem i will have to find out when i get a spare moment tomorrow.
https://www.sau.com.au/forums/topic/262240-r32-parts/#findComment-4492532
Mate, Ill take the indicator stalk, let me know how much for postage to Sydney and you account details, if you still have it, I'll put the funds into your account and send you my address.
Thanks,
Moray
https://www.sau.com.au/forums/topic/262240-r32-parts/#findComment-4499088
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
