Guest RedLineGTR
Sorry to hikjack your thread...but wondering..if i poor water throught the intercooler if thier are any leaks will it show or does it have to be under some kind of pressure to show the leaks?? And where could i get my intercooler pressure tested or leak tested. Cheers
Hi Dion_180sx, aluminium is tig weldable, but it will require someone with thin wall experience. We have had success using aircraft welders, look your local one up in the phone book.
Redline - best way to look for leaks is to pressurise the intercooler with air and dunk it in a bath tub.
That way you'll see where the bubbles are coming from.
I found this link pretty good, and gives you an idea on how to do it;
http://www.vfaq.com/mods/ICtester.html
I had two leaks in my cooler when I got it. One of them was able to be TIG'd up, the other was in a really bad spot so they used some sort of glue on it. They said that the glue they used is the stuff they used on A/C cores, and can take massive pressures...
Not sure it they were crapping me, but it's held up for about 12 months now with no problems.
J
J
Hi Dion, this is the stuff we use on aeroplanes, you get it from the the industry suppliers, not cheap but good.
Magic Bond™ Epoxy Stick Epoxy putty that seals leaks and repairs gouges in steel, aluminum, wood, fiberglass, concrete, and ceramics
On cars we use , Selleys Knead It, you can get it from Repco, Bunnings, Auto One, Blackwoods etc. Much cheaper and just as good.
Hope that helps
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
