R34 East Bear seat in excellent condition.
With modified Raptor rail to suit R32, R33 GTS, GTS-t sedan or coupe & GT-R $700
With New Bride RO rail to suit R34 GT, GTT sedan or coupe $900
Not selling seat on it's own and will not courier / post but will meet you somewhere close to me :/
( I'm in the Sutherland Shire ).
so tempting.. whats the difference between the 32/33 rails compared to r34, which holes dont line up ?
On the R34 GT, GTV and GTT ( Coupe & Sedan ), the front bolt down tangs are in the same spot but on a different angle. The left rear tang ( that bolts to the tunnel ) is much the same, and the right rear leg is in a different location ( out more and back a little ).
Any other questions, feel free to ask :woot:
Not selling seat on it's own and will not courier / post but will meet you somewhere close to me :D
hey mate interested in ya seat does the rail for 32/33 sit fairly low pm me ur number interested cheers or msg me ur number 0438223239
Sorry for the lack of responses. Have been :D with food poisoning ( f*@$ink rainbow chinese resteraunt :mad: )
Will call those who left a number first, then return PM's to those who are locals. For those who asked me to reconsider prepping the seat & rail for a courier, sorry, I'm still not prepared to do it. But if I change my mind I'll be sure to PM you back.
Cheers.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
