Hi i have a r33 gts t and it was dieing in boost the hole time. I thought its was my coil packs and spark plugs i changed them over and it fixed it 90% of the time but if i take it slow into boost it wants to gargle then boost kicks in then runs well. i just want to find out what the little bit of gargle is. Can any one help thanks.
https://www.sau.com.au/forums/topic/262283-r33-gts-t-dies-a-bit-in-boost-why/
Checked all vac/press hoses, check lo/hi boost solenoid and hoses.???
Tighten all (air) hose clamps..(don't strip them though!)
When you say 'gargle', do you mean 'miss'?
What gaps are your plugs running at?
Try Listerment..it hurts, but it's good.
Hi mate thanks for the reply the gargle is like... when i put the throdle down just when it hits boost the throdle is heavy then it hits boost and all is good. its just like it didnt want to go into boost.
well since we cant see the car.....
can you tell us what sort of mods you have?
from the sounds of it so far....
when you boost up....theres some sort of surge.......
but obvisouly when you back off the boost.......it runs ok?
well have you ever through of the fuel system?
i remember someone having an issue with boosting with modifications......but end up having a blocked/dirty fuel filter.......which caused a surge.
what about your fuel pump?.....does it cater for what mods or how much your boosting?
im guessing you have stock motor but winding up the boost?
try give us a bit more info
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
