not exactly...there is a way to keep everything friendly. Its doesn't involve pistons either.
A 1.8mm head gasket is not sufficient a-mod for clearance of lift of this nature. At high revs you also need DAMN strong valve springs for that lift.
People put universal blue on the crowns, put head on, cam belt etc and do a few rotations of the crank, remove the head and look for valve marks. This method, although indicative, can not account for valve expansion due to the heat transfered to it combined with the oscillary motion causing it to not only stretch in length, but also move sideways as it exits the guide. Upping the lift exposes more valve and the sway increases exponentially.
Even the Tomei website state that if you exceed 10.2mm in lift, you need to scallop them (and they do it for free when you buy pistons off them). Tomei pistons are also 0.4mm lower than std, allowing decompression for more boost but also higher lift.
End of the day, it's the owners choice. My question is, do you REALLY want to risk an entire engine?
Edited by pure_methamphetamachine
my engine seems to live quite happily at 9500rpm+ using 11mm+ cams using my method. No piston mods whatsoever.
Edited by DiRTgarage
I'm not saying it is not possible, there are just too many risks to not justify doing it. If you skim the head, if so how much, had it already been done, are you using REALLY good valve springs etc.
Just not a risk I'd be willing to take, that's all.
i see where you are coming from but you must understand im actually building these engines and putting them through more stress than joe average...not just some internet mechanic with an opinion. I always use top quality components and have recently changed spring brands as we have had excellent results with another brand we recently tested.
I have seen builds by 'pro' engine builders go pear shaped quickly due to some guys thinking building high horsepower/high revving RB's is an easy thing to do. There are quite a few pitfalls when building big engines that if you are unaware of can come back to bite you on the ass very hard.
I am neither bagging nor doubting you. It is just my opinion. And yes, I too have seen many "pro" build engines that fail instantly. Yet they never seem to learn...
Bugger about the cams dude. How the f did they manage to break?
  • 9 months later...
paul - my cams are as follows:
A269IN (inlet) has 'U6' stamped on it
A252X (exhuast) has 'U7' stamped on it
lift are identical @ 9.15mm (as per my vernier)
My question refers to the information I have quoted above.
I have purchased a secondhand set of tomei 'b's for my 26. Correct boxes, looks the same as any photos, but absolutely no manufacturer markings or part numbers on the cams thamselves, other than u6 on the intake and u5 on the exhaust. Not really trusting myself with measurement off the callipers I have here, but definitely more lift than stock.
Does the 'u' number actually have any relevance?
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
