From what I can tell:
Front Chasis is a little different
Interior is redone
Gear and clutch seems a bit more refined (could just be me).
Some R34's have differen't headlight setups as well
Were there any differences between the early model 34 and the later models?
I heard that there was a few differences in features and that the early model had problems with their coil packs.
Is this true and if so what are the differences?
Cheers
well im not 100% sure about the R34 GT-T
but i know the R34 GT-R has a whole list of differences..
not major changes but plenty to list.... like the radio, bonnet underlining....paint ECU cover, door trim, interior colour & many more
Cheers
many different, but not very important...
oil filter size difference, turbo difference...
color difference(such as early model have yellow, red and dark blue etc...)
etc..
have a SII r34 and afaik they come out after/during year 2000
1. diff turbo
2. slightly higher torque (not too sure bout the correct figure)
3. diff interior (white background on gauge, dash, black and white on steering wheel)
4. fking ugly front bumper for some (have since changed mine)
5. diff paint - seen mainly white and bayside blue on later models
6. oil filter diff
7. coil pack cover is white instead of red on the word neo 6
not too sure bout headlights, clutch and others
notice how the steering wheel is white at the top, the door trim and the seats
bsb exterior colour
front bar / side skirts in this case have been changed to impul as well as to the gtr wing
usually 3-5k extra for a series 2 vs a series 1 for 34s
Edited by hotchoc
YES YES! different headlights between series 1 and series 2
the Outline of the headlight, high beam and parkers are more of a greyish colour rather than dull black.,..
im pretty sure this is SERIES 1!.........
And series 2...........
The different headlights dont mean series 1 or series 2. The top headlights are the halogen ones and the bottom ones are the xenon headlights. You can get both on series 1 or 2 the xenon ones obviously being a dearer option then the two when purchased new.
well the thing is....you could be right...but...im not sure if your 100% correct there......
because if you notice.....all R34 GT-R headlights are like the 2nd picture with the Grey outline...whether its series 1 or series 2.
alot of the R34 GT-T series 2 have the same headlight as the R34 GT-R......
apparently they come up as the same part no#
im thinking that whether it was Xenon or non xenon nissan changed the design of the GT-T by series 2 by adding GT-R headlights
simillar to what they did to the R33 when they bought out Projector lense for series 2.
ummmm i dont think the headlight pics explain if they are xenon or not.
its NA vs Turbo. the 1st pic are usually off NA R34s where the bulb as the parker light in the 2nd pic are off Turbos.
im fairly certain that is the correct difference but correct me if im wrong.
and to the OP.
they are 2 completely diff cars.
Edited by VB-
and to the OP.
well im not 100% either but you will notice alot of R34 GT-Ts with that black headlights
and ive noticed pretty much all Series 2 GT-T with that style headlight
eeiko321 the reason why the R33 GTR released the xenon projector lights was because it was being sold alongside the R34 in 98 which had xenon lights also and it was released in a series 3 GTR not 2.
They arnt series 2 34 lights as I have seen many series 1's and 2's with both types of headlights they were just a factory option in Japan when new. The reason why all R34 GTRS have them is because they came standard being the top of the line skyline.
They also arnt regulated to NA 34's only as ive seen plenty of series 1 NA and turbo models with both halogen and xenon's. The Halogens seen to pop up more so on the 4 doors but I still have seen 2 door 34 with both types of headlights.
I havent been on here for awhile but if you do a search by a user name of funkymonkey he posted up ages ago (I think) the R34 brochure showing all the different type of factory "extras" you could get.
Hope this helps.
EDIT: Just did a quick search of carsales and found a R34 NA 98 model with the xenon headlights.
Edited by smurf80
Oh dear...I will come back later...
Can you set the record straight please Iron Chef? Im sure with your knowledge you would be able to point out the non correct information in everyones posts. Im going on stuff I have read and seen around the net but if im worng id like to know whats right :sick:
Cheers
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
