what do you guys use?
mine has let go for some reason :D after about 6 or more months, 20000kms after the rebuild.....
i have 300kw atm on gt2860r5s only 15psi....
no need for a head stud kit?
i do plan on running 20 plus psi
also the car never got hot either?......
will be pulling down soon....
https://www.sau.com.au/forums/topic/262338-head-gaskit-rb26/
JUST MAKE SURE you undo the water and oil line connections / supports (10mm heads) on the block to turbo brackets, and these brackets themselves (12mm heads unless people have changed and lost the bolts and replaced, and they'll be a 13mm head [they are an M8 thread]), and the water and oil line connections / supports on the turbos. Also the actual banjo bolts at the side of the turbos (14 and 17mm heads from memory).
DO NOT FORGET you have a 10mm head bolt IN side at front, behind the cam backing plate. You can either remove cam gears, then the plate and access, or, put a 1/4" drive 6 POINT socket on a magnet and put in the gap on the IN side. Use a 6" 1/4 extension and push it into the socket, then use a ratchet to remove the bolt.
Once bolt is out, lift extension and use magnet to get bolt out. Put magnet back in the hole and pull the extention up to make the socket disconnect. It will hit the magnet and you can pull the magnet out and it's all done.
Once head is ready to come off, get 1 person each side (IN and EX) to lift it. Get a third person to push the turbo oil and water lines out of the way, and disconnect the wiring under the IN plenum you can not access ie cold start (on runner [right next to head, purple plug, near cyl 3]).
You will also have to remove on the EX side, a 14mm head bolt that holds the PS bracket on as the lower 2 bracket bolts are in the block. The top is the head.
IN and EX sides at back corners of head also have 10mm headed bolts.
If all your stuff is factory, you will also need to remove the bolts that hold the bracket to the oil pressure sensor housing.
Undo the water pipe (U shaped) that goes from thermostat housing to hard water piping under IN plenum as that rubber pipe is block connection. The metal job is head connection.
Undo the water lines at the factory water cooling at oil filter.
Remove all other obvious stuff.
If you just want to swap it, and not fully remove and inspect, you can leave all wiring side alone, lift the head, remove gasket, ensure the dowells are put back in place and put new gasket on. NOT ADVISABLE as you really want to clean the surfaces, but if you are time desperate like we were on the way to a race meeting, you can do that.
ok played with it for half the day! no drop in comp 160psi in all 6
no water in any....
plugs are all the same in colour?
its leaking oil into the water some were... first guess would be the oil cooler?
dip stick ect is not milky only a very little bit on the rad cap in in the over flow tank, is down say 500mm of oil in around 1000 to 1500kms
quick trick:
heat engine so radiator pressurises, remove plugs and run a small mirror over each plug hole.... if it fogs you have headgasket issues in that cylinder. If you can get hold of a pressure tester for the rad it makes it easier.
Let me guess:
1) You are running a factory block ie non N1 or RRR GT
2) You run 1.3 bar or more, or have hit / exceeded 1.3 bar a few times in the passed
Your block is cracked between where the head bolt goes into it and the water gallery on the outside of the bore. 99% chance it's the cylinder 5 or 4 one EX side). The crack is usually very small, but grows. If you pull the head off you may not even see it as it starts sub-surface. Skim the block and you'll see it clear as days.
You get trace oil accumulating in your radiator I take it, especially in your overflow? You empty it, it comes back?
The crack is small, but as the oil pressure is greater than the water pressure, it forces the oil through the crack into your water system. Over time, the crack will get bigger, and more will start on other head bolt / gallery places. The harder you drive, the faster it does it.
That is exactly what mine and many others have done. That is why the N1 was made, then the GT block, and why I went to an N1.
Changed to N1 block. No problems at 2 bar.
Other friends (boost ran [bar] / time it lasted before oil in radiator):
1.6 / 2 weeks
1.6 / 6 months
1.5 bar / 8 months
1.5 bar / 1 week
1.5 bar / 2 days
1.6 bar / 2 years and still no problem
The time for the cracks to start is random.
You can either replace with an N1 block, or do a semi-temporary / semi-perminant fix on your factory block.
You do not have problem with oil cooler, I guarantee it.
Pull the motor out.
Edited by pure_methamphetamachine
Pull the motor out and pull the head off (you can EASILY pull it off with everything attached outside of the car). Fully drain block of all oil and water. Make sure head bolt holes and water galleries are 100% dry. Add a thin(ish) smear of loctite stuff (see below) in head bolt hole, and put quite a lot in the water gallery, ensuring you go down as far as you can. You can put like 4mm thick of it in there. Allow to dry, put head back on and put the motor back in.
Do this on EVERY water gallery and head bolt hole, but only in the part of the gallery that is next to the bolt hole.
This half @rsedly emulates an N1 block (all the N1 is is a factory one with more meat between the bolt and gallery).
Loctite: Can not remember the exact stuff by name or number, but it is a 2 part epoxy(?). One tube is yellow, the other is black. Tubes are small too, like little super glue tubes. Mix like araldite and apply. The stuff looks like concrete, as opposed to araldite which is clear like a resin / glue.
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
