If you want to get the same performance as this, without the hassle of having your car off the road and getting your hands dirty, give me $160 in $10 notes.
The weight reduction in not carrying over a dozen notes will be even more beneficial than sticking an intake restriction on your car.
  • Like 1
https://www.sau.com.au/forums/topic/262351-hyclone/page/2/#findComment-4601749
  • 5 years later...
been seen these ands on the tv for these hyclone things they fit into the air intake pipe and apparently make better air feul mixture. on the ad they say up to 15% more power and better fuel ecconomy. i wanted to know has anyone got one? they can be used on turbo setups aswell but un N/A guys are always in search of cheap power!!http://www.fuelsaver.com.au/what do u think bull shit what
I don't know, it's a big debate...
It totally makes sense that you'd think it would just restrict your air travel into the manifold.
But on my Land Rover Discovery-ES 1994 V8 3.9L model I managed about 23% increase in mileage on the highway with x2 Hiclones fitted after comparing previous interstate drives (and I drive non-stop)!
Air density could of played a role, but it would still make at least 15% more mileage on the highway with a steady stabilized foot throttle position!
But for city stop & start driving, forget it!!!
Only good for interstate driving in my opinion!!!
https://www.sau.com.au/forums/topic/262351-hyclone/page/2/#findComment-7524056
Did you do another long drive without Hiclones fitted but with new air filters?
https://www.sau.com.au/forums/topic/262351-hyclone/page/2/#findComment-7524229
I started with a K&N Air Filter.
I was doing thousands of kms prior to swapping for x2 Hiclones & I always managed more kms on the highway!!! :)
So I only have them fitted on x2 of my vehicles...
https://www.sau.com.au/forums/topic/262351-hyclone/page/2/#findComment-7525301
Whatever the Tune may be.
Discovery Series 1 is the only vehicle besides Commercial, that could handle 4.500kg towing these days!!!
As you can get Iron Man B Rated Coil Spring for the rear & mine weighed 2.5t wet weight (no sway with a tri-axle flatbed trailer loaded)!
As Dodge RAM 3500HD, Chevrolet Silverado 3500 & Ford F-350 all count as Commercial Vehicles on Rego...
With Dual Sun Roofs, V8 & full leather you seriously can't go wrong! :)
https://www.sau.com.au/forums/topic/262351-hyclone/page/2/#findComment-7525771
  • 3 months later...
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
