hey guys been reading a few threads but not really answering my question.
just rebuilt my engine and bought a second hand (still good) nismo gmax clutch push type, for my R32 GTR, finally got the car running yesterday and couldn't select any gears?? :3some:
before the rebuild it had an organic single plate clutch in it and it had a hard pedal and it was pretty bitey and had no problems what so ever. no leaking master or slave cylinder, never lost fluid.
Bled the stupid set up that nissan used a couple of times and got a good pedal feel and could select gears when the car was off, but when car was started it didn't feel as hard and couldn't select gears.
adjusted under the dash and the pivot ball to try and get it to engage but nothing has worked??
i'm thinking i need to either get a nismo slave cylinder or get the standard one re-sleeved with a smaller bore go give it more stroke because it looks like the slave cylinder is only moving half the distance needed to engage and disengage the clutch.
any help much appreciated
Aaron
https://www.sau.com.au/forums/topic/262405-cant-select-gears/
If the hydraulic system was working fine with the old clutch, then your problem is more than likely related to the installation of the new clutch itself. Of course that assumes that the hydraulic system is in good nick. I believe you need to use a different height thrust bearing carrier with some of these multi-plate clutches, so it might be related to that, but someone else should be able to confirm (also do a search).
The clutch pedal 'feels' different on a GTR because it has vac assist when the engine is running in the same way as the brake system.
I also have the same clutch in my car, going from single to twin I had to actually make a longer pushrod from the slave to the fork.
Reason being the fork sat further back and my slave piston was about to pop out.
It wasnt a huge change but just enough. Might be your problem.
What thrust/carrier did you use? This could also be a problem.
Call Jim Berry, he should be able to tell you straight away but you need to know whats in there.
btw, remember the nismo slave is larger bore so it will have less travel than a stock slave. so if your problem is travel don't get it. I had a problem with my old twin or tripple (i forget which) and hard gear selection. it was not enough travel. went back to stock slave, problem went away.
  • 2 months later...
    • That's awesome. Fully serviced/full log book history for one of those cars is super rare from what I know. With JDM's like Skyline's, Supras, are quite hard to find one with full log book history. S15's seem to be somewhat of an exception, at least the spec s australian delivered models.
    • Hey all, It's been a bit since I have been able to update.  I pulled the fuel pump, first off it was a "universal" pump and the strainer was very clogged, and it was folded over on itself.  I replaced the fuel pump and all is well....  No more stalling.
    • That's convinced me I'll bump up the G30-660 to 770   Any idea if the difference in boost pressure? Cheers
    • When: Saturday 24th of May 2025 - All day Where: Sydney Dragway, Eastern Creek Cost: Varies - Book direct with the GTR Festival Website We will be there on the day with a stand please reach out via our interest form if you wish to help out with the stand. Limited parking will be available in the display area, first in first served with current members getting priority, please register your interest with the link above also. Please post any great photos you take on the day on this thread and we will try use some in our e-mails/website/social media
    • Hey guys so turns out this project is going to be much bigger than I thought haha but I've done some my homework and have done a few panels on my car, but one part I can just not visualise is this. If I do a spot repair and I put filler in a dent for example and sand outside of the repair with 320 grit lets say so the primer can stick as I will only put primer on that repair and the surrounding area and then repaint the whole panel. Don't I need to make sure that I don't put primer on the old clear coat? I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down, it's still shiny. I thought putting paint on clearcoat or primer on clearcoat is a bad idea because it won't stick. So in this scenario it's a bit different to mine but imagine someone doing a spot repair and only painting that small section of repair but the new paint is landing on the old clearcoat. What am I missing?
