The window rattles are starting to annoy me now when the window is half down or whatever, has anybody actually taken the time to fix this? I know its a somewhat common problem, and its not a big issue as my windows are rarely "half down" but i like things to be perfect :woot: anyone got any ideas?
Cheers
https://www.sau.com.au/forums/topic/262436-r34-window-rattles/
You can adjust those things that reduce the window movement
But its weird, when my window is almost all the way up, it doesnt move that much
Halfway down it does move alot, guess its the shape of the window itself
So if you adjusted it to be tight half way down, it might not even close when you try and wind it up
My 33 rattles when they are fully up.
You can adjust the tension on the little fabric feet things. But be aware that if you do tighten them up too much it puts a bit of strain on the bottom half of the mechanism.
In mine, the little plastic roller balls in the track split. And guess what? You cant replace them. You have to buy a new regulator. Just be careful.
And also if you have tints, think about that. The feed rub against the glass all the time. If you get on the right angle with un tinted glass you can see two perfectly clean lines from where it rubs. I would imagine it wouldnt be too nice on tints if its too tight?
But keeping it to the thread, is there any other ways of adjusting them to stop rattles?
  • 11 years later...
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
    • If I had logged into the forum and saw that I would have  Missed out again.
