Hey guys, just though I'd let you know how i went lowering my Stag.
Ended up buying a set of low king springs from a R33 GTST from a fellow SAU member.
Got started, did the front first and it looked a treat, nice height without being a hazard.
Then came to the rear springs which didn't fit!
I guess I should've expected it because the whole operation was going way too smoothly! haha
The rear springs fit fine at the bottom but the stock springs taper inwards at the top to suit the oval top, whereas the GTST springs stay at a consistent width. In hindsight, I should've thought of that, but I didn't. So whatever.
After a little deliberation, I decided to cut my rear springs. Took off a coil and a half and I'm so happy with the results!
Sits very nicely. And almost identical to the front.
Don't know if any of you care, but just though I'd let you all know, haha.
BEFORE:
AFTER:
In fact, in these photos, the change isnt that obvious, but its definitely a noticeable difference!
https://www.sau.com.au/forums/topic/262459-lowered-my-stagea/
Will look mint once the front lip and skirts are back on!
Wouldn't it feel a bit under-sprung right now tho?
SK used R34 GTR front springs, R32GTR fronts springs upside in the rear from whiteline for his kits...
But Access Autoworks can supply you with Stagea Tein S-tech's! (or if you want whiteline i will sell you mine cheapish and go STIFF :down: )
Yeah?
Whats "cheapish"?
And can you offer front and back? Or just back?
Yeah?
Whats "cheapish"?
set of 4... let me price new springs and get back too you... i paid 300ish, they are in good nick, i just need to get a price to get custom length/rate sorted...
And i won't be doing it until my cast is off as i will be doing the change over myself...
-Ryan
Yeah, no rush. I won't have any spare money for a lil bit anyway.
Spending a lot in the next couple of weeks on FMIC, custom piping, exhaust upgrade, bigger better fuel pump, boost controller and a remap to finish it all off. Then next on the list is new tyres.
Then I want to get my kit fixed and back on.
*Sigh*
Edited by Unbalanced
*Sigh*
I highly, highly, highly recommend Bridgestone Adrenalin RE001
needs more low :D
Nah. If I go any lower the kit will scrape on everything!
Going to get bigger wheels sometime which will make it look a bit better i reckon, but first I need some other much more important mods. ;)
haha yeah for sure, just gotta be more careful when you drive/pick lines - it's do-able (see display pic :D )
i'd steer away from going bigger wheels - 18's are about as big as you'll want to go before tyre profiles become too small
BEFORE:
AFTER:
Chopped springs highly illegal in this country. When your wheel is at the bottom of its travel is the spring free to move around?
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
