Meggala,
From experience, at Frankston TAFE dyno, the most I could make on my car was about 184kw at the wheels (I think - I had a unichip at the time) - another car with the same turbo and similar mods (except powerfc I think) made another 5rwkw...
Thing is, that dyno's known to be optimistic by about 5-7%. It's easy to have a dyno 200rwkw, but I'd rather have a REAL 200rwkw.
matt
Originally posted by meggala
they can run to at least 190 boostmeister has got 200+ out of his
but different dynos read differnt amounts.what type of cams (as in 264's or such) are you thinging of getting I have some spare cams if I need to use them.and a rough cost pm me if you like
cheers
meggala
meggala,do u want new cams or YOUR cams machined? cause the machineing of your cams would be cheaper but i wouldnt have a clue,ill find out for u though,cause thats what i was just gonna do,
so yous think a t3/t4 would be a good choice? cause there cheaper than the GT series turbos arnt they,especially if i can get one 2nd hand.
yeah the T3/4's are heaps cheaper. I wouldn't recomend an exhaust wheel any bigger than 56 mm other wise its 2 lagg try and go for a drive in Dr drifts car and you will see. how they are .
If you can get prices cause we might be able to get a few others as well to get cams done. and yeah getting them machined would be better for me as well
you really don't wont to go much bigger than 264 in and rb20 I reckon 256 or 260 would be perfect
cheers
meggala
thing is with a cam it should reduce lagg by a bit,have u got any specs on any t3/t4's i should be looking at,they bolt on dont they? and do they have internal wastegates?
Also im gonna try and get everything then put it all on.so im looking at the front mount,GTR injectors aswell? would they be any good? also a either a GTR fuelpump,or a new bosch style intank pump so no messing around. Have i forgoten anything else?
  • 1 month later...
Yeah i didnt even know this existed.
I still think that there's be quite a lot of leakage from the turbine outlet into the wastegate line since there doesnt look to be any sort of separator.
I stuck one in my R32 with the RB25 turbo (now rebuilt with a very slightly larger compressor wheel ) er.. and bent the actuator arm heaps er.. I can pretty much get to full boost in 4th by say 3600rpm. Choice!
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
