Hey all,
I'm looking at getting a Dremel or similar tool, as, having only moved out from home less than a year ago, I have not amassed a collection of power tools and want something to use for general cutting, drilling and knocking together the usual little engine bay and interior projects.
I went to Bunnings this morning, and they had the following:
Dremel 300 + 10 Acc. $89
Dremel 300 + Flex attachment + 55 Acc. $129
Dremel 400 + 4 attachements + 80 Acc. $169
Ozito - don't really know whats in it. $46
Ryobi + many attachments $104
Also I doscovered at the local hardware an engraver/cutter for $25.
For working with materials like Aluminium and plastic up to 1mm, bits of timber and the like, would the engraver be out of its league? I'm interested to know what people use and recommend. The Ryobi looks like a good set, but at least with the Dremel you wouldnt have to worry about compatibility issues with all the attachments they offer, like the thing that turns it into a pedestal drill which looks awesome :D One thing I do want is the attachment that allows you to cut around like a jigsaw, which the Ryobi has but only the biggest Dremel set has.
I want this to last a long time so happy to spend a bit, but just thought I'd get peoples opinions... cheers :D
https://www.sau.com.au/forums/topic/262504-dremel-rotary-tools/
I bought an ozito one from Bunnings a while back... it's been great! I've used it quite a few times now for grinding little things down here and there (mainly for under the bonnet of the 'line :D) and it's done the trick for me. I'm still living at home, and my dad's a builder... so I've got a fairly decent tool selection at my disposal, so I've never had to use this for actually cutting anything large, for drilling or anything like that... but for tidying up an edge or making a quick modification to make something fit, it's been great.
Just my 2c...
^^ whs.
no good for big projects and the sort, but good for cleaning up and small interior projects etc. i've got a dremel (got the best one, about 3 years ago) i'm yet to use it on anything on my car, but i've used it for small sheet metal cutting (thin intricate stuff) and its alright.
but before you buy, you've just got to accept that they're all weak as piss and i wouldnt use them for drilling, especially not metal anyway (too fast, not enough power).
perfect for polishing small-medium items, etc.
if you want to drill, buy a drill. if you want to cut large amounts or thick metal, buy a grinder and a few cutting disks.
Agreed. Even if you hardly ever use it, sometimes it'll be the handiest thing you own, and the amounts of truly useful attachments you can get for them is phenomenal. But the cheap knock offs are often as good, and lets face it, if it breaks, Bunnings will replace ANYTHING. suckers. gotta love em
Thanks guys, thats helpful feedback :)
I am only wanting it for little things, for instance a while ago I made an air box out of thin metal - without anything better to use I had to use scissors to cut it out which was a pain in the anus, especially to cut the hole for the pipe - I had to pierce a hole and then awkwardly cut little bits at a time until I made a 3 inch circle :( Got there in the end, but would like to be a bit less primitive in the future :(
i bought a rotomax 25 from the usa. (foredom rebadged) its a flex shaft tool. came with a foot pedal and does 20k rpm. has enough power to drive 30mm flap discs into a port :D
well until you overload it and the cable spirals up... new cable is 50 bucks and comes with a set of brushes for the motor..
best $300 ive ever spent. i will never use a die grinder again.
also as its a foredom about 10 differant hand pieces are available with collets or the economy one with a mini jacobs chuck.
ps. a die grinder uses more are than a rattle gun :woot:
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
