hi everyone
just wondering if there are any good books or websites out there that people have used that are great for learning everything about tuning. wanting to learn more the theory behind it all. i do know some basics but want to be more informed when talking to my tuner. i currently have a hks pro v, so unfortunately i cant do any tuning myself but still want to know more.
also are there any good threads on this site specific for tuning rb26.
cheers
ben
https://www.sau.com.au/forums/topic/262531-tuning-guide/
unfortunatly there is no guides for dummys or "how to tune" documents. you have to pretty much work it out yourself, and don't bother asking other tuners because they seem to like to keep what they know to themself's for some reason.
so this is what you need,
aftermarket ecu thats tunable with laptop
laptop
12v to 240v inverter
wideband afr setup
and alot of balls because if you stuff up then you have a broken engine.
good luck
https://www.sau.com.au/forums/topic/262531-tuning-guide/#findComment-4496993
in my history of tuning i have only had 2 motors with issues, they were both built by the same dodgy builder. One of them spun a bearing about 6 months after the tune and the other had bearing issues after being on the dyno for around 20 minutes or so due to oil issues.
I have a good friend who is a tuner, and without him there is no way i would know what i know today and he always pointed me in the right direction to learn, 90% of the time he would not give me answers but give me tips on how to find the answer because you do not learn when someone tells you all the answers.
https://www.sau.com.au/forums/topic/262531-tuning-guide/#findComment-4497285
Excellent thread, i've been considering the same thing myself, just picked up a datalogit for my pfc so thats a start... although i didnt thinkabout the inverter for the laptop... i guess i will need a few hours of battery to do things properly.
As far as the other kit you mentioned GT are there any specific bits of kit you'd recommend. I noticed you seemed pretty happy with the gizzmo knock amp thing (cant recall its name).
Would you say one of these is a must. Also if i'm looking to consider the emmisions side of things (lets say i wanted to do an emissions friendly tune for if i get epa'd) do you have any thinoughts or suggestions on what to look at in that area.
Much like you mentioned i'm looking for guidance as opposed to outright answers. I'd much prefer to understand what i'm doing as opposed to doing it because someone told me to.
Someone mentioned the motec stuff above (courses knowledge base etc) does anyone else have any other resources they care to share.
I know that this or last months HPI magazine had some tech articles on tuning.
https://www.sau.com.au/forums/topic/262531-tuning-guide/#findComment-4497418
yeah i know things like that arent cheap. but i prefer to spend the cash in the right place and learn to do things properly.
I figure that if i'm willing to risk my engine learning least i can do is spend some cash on some kit to help me detect bad things.
https://www.sau.com.au/forums/topic/262531-tuning-guide/#findComment-4497445
Gizzmo K-mon costs about $1200 retail. I suggest you buy a Techedge AFR meter first, www.wb02.com.
You don't even know how to tune yet and your talking about passing emissons test? you need to learn how to crawl before you can run a marathon mate.
After you have tuned about 20 or 30 cars then you should try and work out how to get into the advanced stuff otherwise you will never get anywhere.
Good luck with it.
https://www.sau.com.au/forums/topic/262531-tuning-guide/#findComment-4497641
Good luck with it.
Yeah thats not cheap at all... and they dont have it in the colour i like... AFR it is then :P.
As far as basic compared to advanced tuning tasks go, i understand that tuning to a goal, be it max power or lower emissions isnt as simple as sit down plug in and away you go. But i normally find that i learn best by applying what i'm learning, can you suggest any tasks that would be good when tuning purely for the sake of learning? it seems that without a dyno tuning for power isnt sane and that basing the results on seat of your pants feeling isnt all that empirical. Would detuning for different fuels be classified as a big job eg down to a safe tune for 95 octane then back to a safe tune for 98??
What were the milestones you set yourself when it came to learning???
Edited by Messiah
https://www.sau.com.au/forums/topic/262531-tuning-guide/#findComment-4497741
looks like a good pdf.. ill sit down tonight and have a read.
by the sounds of things if i want to learn more ill have to continue to pick the brains of my tuner.
https://www.sau.com.au/forums/topic/262531-tuning-guide/#findComment-4497875
have a look at this thread, http://www.skylinesaustralia.com/forums/Ro...d+tune+power+fc
that was when i first started, i just wanted to learn how to tune my own car to save on tuning costs and it just exploded to levels that i never even thought about reaching.
https://www.sau.com.au/forums/topic/262531-tuning-guide/#findComment-4497930
the first task for you mate will be to re-set your power fc. and re-tune it completly from scratch without blowing it up.
If you succeed then do mods to your car and re-tune to suit. I only suggest playing with your own car before you start tuning other cars
https://www.sau.com.au/forums/topic/262531-tuning-guide/#findComment-4501491
Cheers GT, that sounds like a plan to me. I can always save the current tune to the laptop anyway if i need to go back to a known safe point.
Regarding safety margins, is the knock meter on the pfc up to scratch when it comes to tuning and can its reading be trusted?
From reading, most guides seem to say "alter timing and fuel until knock is detected and back off 3 degrees or so " or something similar. If the pfc's knock meter is rudimentary at best i'm worried that by the time i pick up that its knocking the damage is already done... even if it is below say 20.
https://www.sau.com.au/forums/topic/262531-tuning-guide/#findComment-4501854
    • Welcome!  We're not all grumpy.
    • Welcome. We're all grumpy old men (and a few grumpy old women) who are slowly coming to hate these cars. Any of the newer owners who have joined in the last few years are rapidly catching up with us as they realise they have bought a basket case and that parts are getting difficult to find. Just be realistic about your goals. You'll need a fat stack of cash to buy an R34 GTR, and you'd be far better off using that to buy absolutely anything else (ie, shares, a house, scratchy tickets) unless that fat stack of cash is only ~10% of the actual fat stack of cash that you have. You'll never want to drive an R34 GTR on the street if you have fear of it getting destroyed. That's more or less true of the 33s and 32s also. Most of the RWD cars have been drifted backwards into power poles. No-one knows what they are worth these days because they are not changing hands. My car has notionally been down to <$10k value at some point and was probably sellable for $40-$50k in the height of COVID stupidity, but I have no idea what it's really worth now. It's irreplaceable anyway, because... where would I find one to replace it? Being realistic means either paying a lot of cash for a really really clean example that you will only drive on sunny Sundays, or buying one to daily that you will not want to be really really clean, for the same fears of destruction that applies to the GTR. I daily mine and some people think I'm crazy. But....to me it's just a car that I bought last century with the express purpose of driving it as my daily. The silliness that has happened since doesn't affect my original purpose. I have well and truly amortised the initial purchase cost and most (probably all) of the subsequent modification costs. But I don't think I could go out and buy one now to daily.
    • This is insane! The M1 likely to be closed for the entire day!  https://www.abc.net.au/news/2025-05-02/m1-motorway-delays-as-metal-shards-cause-flat-tyres-/105242272
    • Hey everyone! I'm quite young and I don't have enough to get a car right now but I love Nissan Skylines (Specifically the r34 GT-R. I'm so original I know.) and I would love to buy one in the future. I have no background knowledge, only an interest in cars, but I'd love to learn how they work so I can mod in the future. I've done some basic research on what model of Skyline I would start with and what mods to get started with are but nothing else. I'm here to learn! Hope you all have a great day
