I got mine $65 exchange I was gond buy some sard injector for $1300 so for almost a grand less thats another 22 cases of beer for me to drink :P
Where from?
I got the Denso's for my 30 before the dollar went to shit, haven't looked recently but probably a lot more now..
  • 1 month later...
you all seem a little bit optimistic with your power out puts 210-240awkw with no after market ecu?
i can only give advise on my own experience power-fc, front mount, 3" exhaust, dump pipe, 10psi, 044 bosh fuel pump.
gives me 200awkw my now problem is airflow meter is maxed out and need a bigger one (stupid power-fc) and my injectors need replacing as there up the pointy end of there duty cycle. what i did find out is the neo will never make as much power as a 33 as the neo come with smaller injectors plain and simple need more fuel to make more power.
has anybody found out if rb25 injectors fit the rb25neo?
matt is right, when modding my stagea my power was quite low with all my mods, 125kw before the power fc was installed which shot it straight up to 200.9rwkw
To get any decent power increase (ie. >30kw) you will need tuning - at least just to keep it from running way too rich.
And to go anywhere over 180-200rwkw you'll need a bigger intercooler & possibly fuel pump.
Anywhere over 200kw will probably require a larger turbo.
I found that after around 160awkw things can start to get quite expensive.
Also note, the difference between awkw and rwkw on these cars is not that much. In my experience it works out to about 20kw difference. That difference is not a percentage, so it doesn't increase (much? at all?) as the power increases. At over 300rwkw the difference might be slightly more, but I'd guess that 330rwkw is around 300awkw.
The reason awkw is lower is due to the drivetrain losses - ie. the extra load caused from driving the front wheels. This extra load does not increase as you increase power, so therefore awkw will always be ~20kw less than rwkw.
    • Nismo 300km/h speedo for R33 gtst in GTR cluster.
    • Has anybody had their wheels refurbished? I reckon it's likely bloody expensive. Even a sand blasting quote for my 17s was 200-300 per wheel! The E39 wheels are basic BMW M Sport (or M Tech at the time.) they have slight rash and some have signs of bad repair in the past on the lips. The main issue is that they've become really off coloured.  I think it will be too much as this is definitely (supposed to be) a budget resto. I've been looking at others for sale but they all have some minor damage and colour issues.  In the end I think I'll just need to sand blast them myself and do a respray.
    • Trying to figure out which nismo cluster i have. All the ones i see on the internet, the speedo goes up to 320kph and the revs 11k, with the nismo logo being on the rev gauge only. But on my one, the speedo goes up to 300 and says nismo, while the revs only go upto 10k and no nismo logo Dunno how to embed pics into a post so ill attach pic of my cluster and generic google search for reference Is what i have genuine?
    • how does one remove the needles from the gauge cluster on a R34 GTT?
    • Furthermore, to obtain the correct torque value using a torque wrench, use this sort of tool rather than trying to just slip a spanner on there and hoping for the best https://www.ebay.com.au/itm/134997056922?_skw=tie+rod+tool&itmmeta=01JV4F9X0JG2T790PDTYY5XA5C&hash=item1f6e739d9a:g:l1cAAOSw8Q5mBSWf&itmprp=enc%3AAQAKAAAA4FkggFvd1GGDu0w3yXCmi1ehLELIotiBW9ttZY4Avbcw7tIQoAebP9lUKZOfgmr%2FvoyKD0w%2FsryPVoxqpduETEeCq2mpbl1NI5I3OLvNCAR7gYTcWcqn5OW87VWEC3PzWCZel4jW%2FwOjhWx636ZkbVuSY5aaNvIRyIK1rPuGVwUPrsAavS0EEnbtTxkbvwU%2BaS5UeTfkeweMKaNZyIX2ex3QWq7aFVvNsnVwH%2BohFZ09zyW1qu8sjMo6%2F5D5xIDwkMugxXJiBjl4XN2otrl6Q8CGqp6yPZ2eEG5biaKo1p31|tkp%3ABFBMxtCnj9ll
