2 of SR3 for sell, model same as the one in the picture, will take some pics this afternoon.
These are in good condition, I just spent near $300 to replace the form of side support. Need to sell them make way to a set of better suspension.
ask for $1300 for both. Sydney buyer prefered because it's too big to send.
also accept swap for a set of good condition of jap coilover, height and damper adjustable for R33 GTST.
https://www.sau.com.au/forums/topic/26262-2-x-recaro-sr3-for-sell/
  • Replies 41
Hi, Guys..
These come with rails and base, but the one bolt on floor need light modification, since these were not off R33 GTST.
when you refer to rails, you mean the one under the seat or the one on the floor? these come with the one under seat, but need the one on the floor modified..
Originally posted by sidewaymambo
Hi, Guys..
Ummm - I just want to take my old seats out and put new ones in without too much modification or ripping stuff off my old seat base/rails -
PM Me with contact details/phone number , or call me tomorrow on 0402 030 038 (Brendan) - I'll come around tomorrow to check them out.
Cheers,
you don't need to modify your original rail and base..because these seats already come with both..and you only need to modify the one bolt to the floor. hope this help.
Steve, I will keep it mind, because I still wait for someone who offered me a set of suspension to confirm, so atm still for sell....
Kewl - that's what I thought - Keen to see them tomorrow - will bring cash !
Originally posted by PranK
Either way, I have to sell my seats first and then I'll be able to buy them..
PranK,
I may be able to help you in this endeavour !!
please send me PM or preferably email. let's resolve this quickly so everyone wins !
Cheers
BD
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
