I have an R32 Nissan Skyline GTR shell, it was stolen recovered but it has compliance plates and CAN be registered if it was put back together.
The shell will not be rolling and WILL INCLUDE the following only:
Bare shell
Driver and passenger doors (no window motors, trim, or switches)
Front glass
Rear glass
Both rear 1/4 glass
Driver and passenger glass
Dashboard Bare
Interior Carpet
Fuel Tank
Wiring for entire car is still intact
Fuse box
Bootlid (no badge)
Rear Bar
Heater and aircon underdash boxes
All sound deadening appears to have been removed
WILL NOT COME WITH
Obviously some parts you can see are missing but I will just add
No front or rear cradles
No Seats
No running gear
No Lights
No Piping
No front panels (still have guards available)
Anything your unsure of please ask, I do have other parts available if you want to rebuild.
Price is $2000 FIRM which I think is very very cheap. Could be a very easy and cost effective fix for someone who has badly crashed their GTR, wrapped it around a pole or simply wants another shell to start building up.
Located in Adelaide will need to be picked up on a car trailer, can help get it on.
Edited by AX-onevia
free bump, but only to suggest that if someone is intwerested in this, they could combine it with my gtr 32 that has a bent shell, but has all the mechanicals, for $8K or a front 1/2 for $6k
check out my post on here
Thanks
or PM me
hello i am from tasmania and i want to buy your GTR shell could u please send me your number or you can call me on 0439748094 asap please as i have twisted my GTR shell but all running gear is ok all i need is a shell, looking foard to hearing from you cheears ben
Hey i was wondering if it came with atessa, fuel tank/lines, brakes, suspension, hicas etc. also i was wondering what parts you had that are missing off the car
Edited by 2FST4U.R33
  • 3 weeks later...
i can come and check it out this weekend if u PM me your adress, should be free sat arvo and sun morning. Otherwise in adelaide again for the drifting on the 23 and 24.
also did u get the text i sent you if not plz pm me you number as well
  • 3 weeks later...
  • 4 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
