the power fc is very good but you need to use an ecu that some one in russia can tune? other wise there is no point. the good thingabout the the powerfc is it comes with a basic map.
the blitz ecu might be good if you dont have some one to une your car but you wont get the best results.
meggala
Hi Vovan, Power FC standard maps are pretty copnservative so you should have no problems just plugging it straight in. You can then tune from there.
The Motec F&W lambda sensor and display are the best way to tune yourself. That and someone to watch the Commander display. You should also consider the Datalogit software. www.fc-datalogit.co.nz
The advantage of the Motec ECU (M48 up) is you can buy self tune software for it, which is used with the Motec lambda sensor. Connect it up and it tunes itself, closed loop all conditions and loads.
Add up the costs, it may in fact end up cheaper that way.
Hope that helps
