hi guys
i got some parts i really want to get rid of
cause at the moment there taking up heaps of space.
HKS coilovers (the purple ones) $670
front headlights $210
genuine bonnet lip in gunmetal grey $140 only reason why its priced at that is because i would like to keep it
r32 standard turbos with dumps $300
gearbox 600
COMPLETE GTR RUNNING GEAR, complete complte with everything
from front subframe too rear subframe.
basically everything was unbolted and dropped to the ground so brakes,hubs discs brake lines diff drivshafters tailshaft
everything underneath is forsale. would like to get rid of it all at once if not then ill start seperating
anyquestions please dont hesitate to ask will take offers for the running gear and i wont be to fussed cause i relaly just want it gone as well as fund my build
will take trades for anything rb26 like, loom,pfc,gt3540,highmound manifold,ext gate etc
can be contacted through pm but will be much easier by fone or email which ever, fone would be the fastest
all items are located in melbourne springvale. not willing to post unless buyer pays for postage too much hassling around to go post items.
cheers tin
[email protected] or 0412-219-552
Edited by tin-pain
https://www.sau.com.au/forums/topic/262702-r32-gtr-parts/
Any pictures mate?
Edited by Excess
https://www.sau.com.au/forums/topic/262702-r32-gtr-parts/#findComment-4499899
condition of coilovers? adjustability?
these are in excellent condition. height and dampner adjustable.
no pictures as yet cause theres no time for me to do so.
welcome to come by cause im at work from 9 till late anyway.
located in springvale off westall rd.
https://www.sau.com.au/forums/topic/262702-r32-gtr-parts/#findComment-4500677
Any pictures mate?
these are still in goood condition. headlight no prblems. lip is awesome and the r32 gtr turbos and dumps are still on the engine.
welcome to come and inspect.
https://www.sau.com.au/forums/topic/262702-r32-gtr-parts/#findComment-4500680
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
