After riding shotgun in my mates series 2 Stagea i was wondering if its possible to install a tiptronic gearbox,selector,etc in a series 1?
The gear changes[using the buttons on steering wheel]seemed a lot quicker & more responsive than when i manually change them on my series 1
i dont know how well it will bolt up to mounting points, the bell housing pattern should be the same but you'd have to check the g/box to chasis mounts as well as tailshaft compatibility. also you would have to run a S2/R34 ecu as the auto is controlled by this (not a straight swap, rewiring would be needed maybe additional sensors???).
i'd say it could be done, but i think the time, effort and money involved in doing it wouldn't be worth it. it could be better spent on a manual conversion or shift kit and other upgrades for the auto you have.
Edited by QWK32
  • 7 years later...
Any news here ?
I have the same idea.
Stagea S1 and S2, both have the RE4R01A Transmission.
If i want to upgrade my S1 to a Tiptronic, do i have to change the gearbox or only the shifter and the gearbox-ecu ? (I dont need the shiftoption on my steeringwheel)
Hope you guys understand what i want :-D
Best Regards
Andi
Any news here ?
Best Regards
Andi
It would be a lot easier and better to sell the S1 and buy a S2 (especially if you don't already have the Neo engine).
  • 7 years later...
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
