dude thats schmick
my end, they are making me a GT30 at ATS (marion rd) new lines gaskets etc.
ball bearing fast response, ported rb housings, flow-tested to 270kw
will get that bolt her on fix everything up and be up for a cruise in a week or so
let know how it goes... is spoke to ats bout one a little while back...
  • Replies 69
Firstly, Hi guys.
Over at OZVR4 we are talking about a wagon cruise out to the drift day at Mallala. Be cool to see some Stageas come along. Just a nice casual cruise I reckon.
Hopefully cya there.
I'd be up for that. I haven't seen any drift for a while.
The cruise is looking like the 23rd if May, if it ends up happening.
Somethings come up and I wont be able to make it, spewing, however, I am in the process of organising a cruise on the 30th May. I am also trying to get numbers for a Glowridaz car detailing workshop before the cruise. I have 4 spots left, so if anybody is interested, pm me. Its $50 which gets you lunch, drinks and covers the products. They basically run you through the right way to clean your car, and show you tips and which stuff to use etc. etc.
Looking forward to getting a bunch of wagons on the road.
That’s really interesting.
LOL!...WTF!!!!....how about you add something interesting.....this is the third time I've entered a thread and seen this stupid comment from you!
  • 3 weeks later...
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
