  • Replies 203
Hmm google has no idea.
google seems confused lol
this is of my interest.... not that i would probably do it but it would be such an awesome mod!
Currently in the process of this, LS2 engine and box has been acquired, just waiting on mounting kit from states to arrive then I can get the ball rolling.
so engine+gb+mounts
then im assuming a headache for wiring?
Much else?
so engine+gb+mounts
Much else?
Not necessarily a headache for me, have a wiring guru that will sort it out so it'll be for him lol
Really need the mounting kit to arrive so engine can be bolted up, new sump on, fuel sytem can be started, exhaust can be started, lines can be made etc etc.
I already know there will be hurdles to overcome but it'll be sorted.
The angering of the Nissan gods for desecrating a Skyline with a single camshafted taxi motor.
lol ohh they're pissed believe me but they'll love the skids!
anyone tried putting the CREE LED's in the reverse light (in a coupe)? Im finding it really difficult reversing in unlit areas at night, especially in areas where theres lots of little obstacles and a little more light would be helpful
If you guys are on FaceBook, request to be added on "V35 Coupe Drivers" group, it's run by American's with G35's but there is A LOT of knowledge to be gained by these guys, you can post questions and pics and get an accurate response most of the time, just like this group.
@Trav i did see guys on that group talking about the reversing LED lights would be an idea to join and ask about it.
lets play a game called... is it gay
audi RS6 rims in grey on a white v35 coupe?
similar link - http://www.ebay.com.au/itm/19-AUDI-RS6-S-LINE-STYLE-WHEELS-FIT-ALL-AUDI-A3-A4-VW-GOLF-JETTA-PASSAT-/270966131663?pt=AU_Car_Parts_Accessories&hash=item3f16d70bcf
i know ill need adaptors and spacers etc
Edited by NORBY
haha size wasnt actually there for reference... im looking into 19s, my factory 18's look way too small in those chunky guards
edit - updated link above to reflect sizing
Edited by NORBY
20" = Uleh / Gay as f**k.
Those 19s - fitment fail. +45 :no:
so much uleh!
I should have just found some actual ones i was looking at, they were 19x9 + 35 (with an adaptor/spacer to 114.3 and 25mm) they'd sit nicely i think.
I meant more peoples opinions on putting audi rims on a nissan...
    • On the compressor side it looks like the best, if your head setup will support doing 100-110lb/min at 30psi-ish boost.   The G45-1350 compressor looks ideally better if you need closer to 40psi for it, given both the G40 1150 and G42 1200 look like they'll be around the 100lb/min mark at 35psi and dropping from there.   Bear in mind the turbine sides are all different between those three turbos, so that COULD be an influencing factor for how they all perform in the real world as well.   Not sure if you've made a conscious decision to only look at Garrett or not, but at least on paper the XRE7169S matches or beats those other three at everything from 30psi up and just going from wheel size alone likely to be at least as responsive as the G40 1150 and seem to behave closer to G42s in terms of turbine flow.
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a one-time tool to do something, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
