1998 R34 GT-T Semi-Auto 2.5L Turbo for sales $16500
Silver, 103000km,Buy it from dealer last year. never crash before.
selling due to change car.
interior mod:
Full set leather trim sit and interior, interior led light(blue), Poinner CD player, JDL speeker, Sony sub, Kicker 4channel Amp.
Window tint. Steelmate Alarm .
Performance mod:
HKS turbo timmer, Cusco Front and back bar, HKS spark plug, HKS super flow air intake, Nismo fuel regulator,
Nismo Full Body Kit, Silver Carbon bonnet, 18" wheels, 3" X-force sound control full set exhaust
X-power ignition votage step up, Bilstein suspension
REGO just paid rego until 3/2010, servies every 5000km , car in good and clean condition.
It is a very nice GT-T, Test driver welcome,feel free to contact me for any enquiry, price is negotiable.
Thanks
Contact: Ivan
Phone:0403412899
E-mail:[email protected]
nice one but may I know why is it kind of cheap ?
It is because it is a Semi-Auto one and I want to sell it quick , I am living in Hughesdale , it is near Oakliegh.
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
