RGS Posted October 5, 2003 Share Posted October 5, 2003 OK Boys I have a problem, I just installed a Response 4ch and a Pioneer DEH-P5550MP and all is sweet until I turn the engine on a and get alternator noise.... I tried putting a Dick Smith capacitator on the alternator but it didn't work! Pleas help - I have a six hour trip next w/end and dont want to listen to that damn whine.... Link to comment https://www.sau.com.au/forums/topic/26285-engineamp-noise/ Share on other sites More sharing options...
JR Posted October 6, 2003 Share Posted October 6, 2003 how big is your power cable and you earth cable, where is it earthed? and how big is your return cable to the battery?? Link to comment https://www.sau.com.au/forums/topic/26285-engineamp-noise/#findComment-558078 Share on other sites More sharing options...
hippy Posted October 6, 2003 Share Posted October 6, 2003 yeah i think its an earthing problem .. Link to comment https://www.sau.com.au/forums/topic/26285-engineamp-noise/#findComment-558095 Share on other sites More sharing options...
AutoTrust Posted October 6, 2003 Share Posted October 6, 2003 Chances are that it is an amp. Skylines rarely have problems with this, also some amps will only whine on high frequencys 1st stop should be Jaycar if it's a new amp and try another. if they wont help then make them. make sure that your Rca leads are good quality and dont run too closely to electronics such as the ECU. Link to comment https://www.sau.com.au/forums/topic/26285-engineamp-noise/#findComment-558126 Share on other sites More sharing options...
RGS Posted October 6, 2003 Author Share Posted October 6, 2003 OK thats a start - I run OK RCA's but nothing flash. The amp is a Jaycar Response 4ch (New). The leads run from HU left and along the passenger side of the car into the boot where the amp is on a nice shelf next to the battery which I spent ages making. The AMP is earthed to the same -'ve terminal as the battery ie that piece of metal with two nuts attaching it to the chassis. The +'ve lead rund from the battery no longer than 1ft to the amp. All power cables are as thick as my little finger (about 1cm ish). Suggestions? Link to comment https://www.sau.com.au/forums/topic/26285-engineamp-noise/#findComment-558324 Share on other sites More sharing options...
AutoTrust Posted October 7, 2003 Share Posted October 7, 2003 Undo your kick and scuff panels and pull the rca's away from the computer and the main wiring harness and have a listen, if it's still the same go see jay car and ask them if you can try another amp. Link to comment https://www.sau.com.au/forums/topic/26285-engineamp-noise/#findComment-558441 Share on other sites More sharing options...
Fhrx Posted October 7, 2003 Share Posted October 7, 2003 Make sure you also upgrade your negative to body. What ever size power cable you run, you'll need the same sized earth. Link to comment https://www.sau.com.au/forums/topic/26285-engineamp-noise/#findComment-559088 Share on other sites More sharing options...
raasclaat Posted October 9, 2003 Share Posted October 9, 2003 yeah keep the RCA's away from power Link to comment https://www.sau.com.au/forums/topic/26285-engineamp-noise/#findComment-561756 Share on other sites More sharing options...
