nah not really open to trades, unless it's something more saleable for around the same value.. you know like a ford or holden (r8 or xr6 or xr8 etc) type thing.
A Honda ZRF400 + 11k i'd trade it for in a second (it's the bike i'm selling this car to get)
price drop to 19,500
Got my motorbike licence on sundy, can't wait to start riding, but need to sell this to get my bike
Rims are getting resprayed this week in standard colour (have a few scratches + a bit of overspray of some sort from my panel shop messed the finish up, so they're doing it free) Proper sand blasted powder coated in the original finish (tyres off etc)
Edited by GTAAAH
How was the compression test performed? Am I missing something because 120 (PSI I assume) is low for a fresh engine. It should be up around the 170 mark. Was it done with a different set of measurements?
Edited by Marty_R
im pritty sure its a low comp engine mate. since the rebuild.... there fore he can run more boost and make mroe power....
test was just done while engine wasn't at highest temp. Thing you look at is variance in between cylinders, it's got forged pistons so they need to expand etc before comp will go up to idk 145ish
Happy to take it to mechanics etc to be checked over.. at your expense of course, car is in panel shop next week to get the rear bumper resprayed, (it got nudged at a set of lights, just a scratch but meh i'm not paying for it)
up, wow no ones buying atm
Have only had 4 people come around to look at it in the last 5 months, which is crazy considering how cheap it is.. what the?! Only one serious person too, bleh
Edited by GTAAAH
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
