Another addition, When i was looking at the turbos and wastegates, it looked like the actuator rods were too long? the wastegate "tang" was not in the middle, it was going toward the rear of the car. How far do they have to go to keep the wastegate open? I saw this when the car was turned off.
Edited by MUNDA
if your making no boost at all, then i would guess your wastegates are stuck open/opening as soon as there is pressure. Possibly sonething wrong with your wastegate actuators ?
Already suggested this. I assumed he had already checked these.
Actuators push the rod towards the rear of the car. Pull the e-clip off and lift the rod. If you can pull the flapper towards the front of the car from that point, then you have an actuator stuck open.
With the rod off the flapper, if you look through the hole in the rod and the flapper fully closed, only 1/2 - 1/4 of the pin on the flapper should be exposed by the hole. This means you should have to pull the rod towards the back of the car to get it over the pin when the flapper is fully closed. If not, then it's loose or open. Boost problem fixed when you buy new HKS units
Just opened her up, took a look at the actuators. They seem to be closed now, i have attached a picture below, do they seem correct? The are going slightly toward the front of the car. I also took a took at them with the car on idle, they stay in the same position.
Oh, and both actuators are in the same position, slightly forward as described in the picture.
Edited by MUNDA
You were told how to test them. A picture means shit.
They only have to be open 1mm and you won't see boost til 6000rpm.
I don't mind helping out but geez man you gotta follow instructions.
Sorry. Someone needs to knock some sense into me, i need to learn how to read. It's late in Canada, i was going to get ready to go to bed that's why i didn't check by taking the actuator off. I will follow the testing steps tomorrow and will re-update this thread.
If the actuator is working, but not closing fully, does that mean it's stuck, or just doesn't have enough strength to close the gate? In that case, can i adjust my actuator rods to close the gate fully?
Sometimes they can be re-adjusted but other times the diaphram spring is shot and it's not able to be fixed. If you have the time, adjust the rod first. See how it goes. They can still have spring tension but sometimes open at 1 or 2 psi which causes the same issues. That needs to be tested with a vacuum/boost checker (we call them a mightyvac)
No I am referring to when the actuator starts to open up.
If the spring inside is shit then you can try to adjust it, but it may not fix the problem...if it doesn't then use a mightyvac to see what pressure opens the actuator.
I'm gonna charge you for a plane ticket in a minute.
Alright, so i took off both actuators, looked at them, and they were fine. The springs seem to be hard, and the actuators were NOT stuck, i followed your steps. i really don't know what to do now. I'm completely lost, i have absolutely no idea with what could be wrong?
What else could it be?
Thats a quick video that i made, you can clearly hear the turbos spinning on brake-boost. Note, when the car turns off, that is not due to a stall, after revving like that, the car usually dies, i dont know why, maybe this video can clarify something?
Thanks,
MUNDA
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
