Some Heathcote pix
predator
 Share
Great day for it... Most of the guys got plenty of runs, and some good matchups between many of the guys! Even though I had to sit at the sidelines this time, great day for a drive and seeing some cars battle it out.
Well i've whacked up some pix I took with my shitter cam in a whole of 5 mins. Works but don't expect fantastic web design skills to shine through :)
http://www.gamebiz.com.au/other/heathcote/index.html
  • Replies 97
Was a great day.good to meet more sau members and put some faces to names.Some great cars to.Thanks for a good day to all that came.
Now i can finally put a face to that post whore RedLineGTR :)
edit-better make that post whore.whore is a little harsh as i heard u dont even put out. :D
Originally posted by riggaP
Great day, I had an awesome time. I got some pics too but cbf postin em up now, they will come 2moz.
Best 2 runs:
13.8312 @ 101.50mph 60ft 2.2039
13.9017 @ 100.81mph 60ft 2.2492
riggaP
very curious as to what mods you have to get those times...
It was a great day, lotta fun..but we had problem after problem, thanx to the BMT guyz that did what they could, thanx mates...Too bad we had to tow the thing back...:) next time i guess we can get into that 11sec margin...
Originally posted by GTR-34
It was a great day, lotta fun..but we had problem after problem, thanx to the BMT guyz that did what they could, thanx mates...Too bad we had to tow the thing back...:D next time i guess we can get into that 11sec margin...
thats no good mate! oh well hopefully when i come to one of them u will be running so i can see the beast in person and take some pics so i can finish the wallpaper/posters :D
Paul - those times are unreal for a stock car!! awesome conditions today too... spewing i couldnt come.
MORE TIMES!!
what did dave end up getting?? (leewah)
did nigel manage to get the car back together in time?
did dave (BMT dave) end up getting endless there?
yeh endless got there...well it nearly didnt hehe...it did ET's of around 12's but it had good milage on it doing around 128mph i think it was..and then it too broke something not too sure wat it was...But impul did well. Pulled a 11.7 i think it was..Gr8 day it was and we met more new ppl...
Originally posted by C_DawG
Endless broke the Input shaft i think, at the line.
yeh it was something like that, it happened while doing the burnout on his 5th run i think it was, so it lasted more runs then calder..hehe
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
