DOOR TRIMS (BOTH SIDES)
CLUSTER SURROUNDING
GREAR SHIFTER BOOT
CLIMATE CONTROLS
REAR SEAT ( 90 MODEL)
THANKSS
I have the rear seats (GTS-T) from a 90 model if you're interested, send me a PM as mine is engineered to be a 2 seater anyway.
CLUSTER SURROUNDING
GREAR SHIFTER BOOT
CLIMATE CONTROLS
THANKSS
Dunno where you is, but I'm in Westside Brisbane, got most all what you need. PM me
tks
hi how much for the lower part of the seat and 2 door trims. wat model are the seats from?
thanks
I HAVE REAR SEAT UPPER AND LOWER
ALSO DOOR TRIMS AND REAR SEAT SIDE TRIM IF INTEREST
IN MELB
PM ME IF YOUR INTEREST
  • 3 weeks later...
