Hi all,
Just wondering if anyone can help or explain why i have bad radio reception in my r34 and if it is a common thing.
Atm i have a jap radio system with one of those aeropro frequency expander. The radio seems to be alright when the car is sation, but when your driving the reception is very poor.
Any ideas as to why??? :P
https://www.sau.com.au/forums/topic/262887-bad-radio-reception/
Hi all,
Any ideas as to why??? :D
If you don't have an external "whip" type antenna, then the existing antenna may be integrated into the rear window, and appear to the eye as part of the rear demister. (usually at the top) This type of antenna does not receive as well as the traditional vertical whip.
Sorry to side-track the thread, but I have an R33 with really bad radio reception. I have an adapter I bought from Autobarn, and my radio reception works but is extremely weak (I can't always receive Nova/Fox in most areas).
I have a Pioneer headunit and I have disconnected the rear aerial unit because of this, I'm starting to think that maybe I should plug the aerial power back into it and disconnect the head unit to aerial wire.
Would the aerial power cause issues like this? Really bad reception?
I read a tip off here that you can disconnect it to stop it going up all the time due to the issues with Pioneer head units (always up even when using USB or CD)
Pioneers dont always do that, some use amp turn on wires, some use antenna power wires, both blue on the radio?
or you can put in a relay to put the antenna up with a switch ?
all diversity antenna setups, have reception issues, mutipath, and signal drops, add hills and big buildings and its worse. and a lot of people hack the cables up instead of using the adapters. making it much worse
a simple antenna seems to work the best or amplified one like VW or BMW uses?
I listen to 90% USB anyway, I have to make a switch for the ATTESA controller, might wire up one for the antenna at the same time.
There is an antenna power wire, the amp turn on wire is separate, I have used an adaptor for the aerial...
Re-plugged in the antenna in the rear, I somehow accidentally removed my antenna trigger wire at some point, probably during the amp wiring....
Anyway, I've got half decent reception with the aerial down, it will stay that way :P
Just don't disconnect your aerial in the boot because it makes reception really bad...
Anyway, I've got half decent reception with the aerial down, it will stay that way :)
I have a pioneer head unit as well and i get better reception after i cut the trigger wire for the elec antenna and leave the antenna down.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
