Dropped a new 32 rb26 into my 32 gtr. Took it for its first test drive about a month ago and it was boosting to 1 bar but seamed very very laggy and just didn't seam to have any power.
It was blowing smoke so we decided to clean the cooler piping as it was full of oil from the previously blown engine.
Test drove it last weekend and it wont boost past 0.5 bar and still feels extremely laggy. It feels like you hit a brick wall at 0.5 bar.
We have cleaned the afm's put new lower gapped plugs in. We are thinking to try different coil packs aswell.
Another thought is it could be a blocked cat. That might explain the lag as I am running hks 2510 turbos it should be extremely resposive.
Any ideas?
https://www.sau.com.au/forums/topic/262900-new-26-in-my-gtr-not-boosting/
as the boost starts to approach 0.5bar it starts to slow down.. if you keep your foot held flat it, it never revvs out nicely on 0.5bar.. it starts missing n the misses seem to get bigger as it revvs out.. also it doesnt just hit 0.5 a bar nicely, it starts slowing down about 0.4bar. the misses arent sporadic like the usual electrical ones that come and go.. its pretty much the same every time, we've cleaned afms, changed spark plugs and checked vacuum leaks...
Edited by jarrod83
I actuslly think the base timing is off by 2 degrees so ill check that first thing tomorrow.
Turbos are both spinning fine and i picked up my consult cable today so i will have a look at what the ecu is doing tomorrow.
I have anotherfuel rail so i might swap over regs aswell
Ok so had a play with the GTR on the weekend.
Put on a high flow can changed coil packs. This has helped(Car much more drivable reving a tad quicker) but problem still not sorted.
We got out the trusty old Motec lambda meter and wow on boost she if hitting 0.663 lambda or 9.75afr
We changed over the FPR to another stock one i had and checked the return line for blockages.
My injectors are yellow topped??? If i recall correctly the 32 RB26 stock injectors i sold last month were not yellow.
Could after market injectors be causing the over fueling(Assuming they are after market)?
Also i noticed a regulator type thing on my spare fuel rail on the return line the rail currently on the engine does not have this?? any one know what it is used for?
Any ideas would be a big help.
Did you even check the fuel pressure before swapping out the reg?
Bit silly to swap it without confirming that was the problem...
No i haven't had the ability to check the fuel pressure I will be borrowing a gauge kit to check it.
Reg was swapped due to the top of it being able to rotate which didn't seam right as the spare was on solid.
Not really silly as swapping didn't help meaning more than likely it was not the problem(That is of course assuming the spare is in good working order)
You dont know the spare was in working order, because you haven't tested either... that was my point.
Replacing parts, without the proper checks, will just mean simply that you'll take forever to find the true cause
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
