So how many peeps are you looking at so far?
I'll be at Chatswood for the meet and probably go for a part-cruise with you; have a dinner around 6 so will take off somewhere in between Chatty & Palm Beach.
Hope Chatswood Chase isn't chockas tomorrow afternoon!
  • Replies 88
hmmm... go to Talbingo for family stuffs... or go to Chatswood/Newport/Palm Beach for car stuffs...
Historically, car stuffs took priority :P
Talbingo like snowy mountains talbingo?!
im in for this aswell, first cruise with the skyline! woo!
That's the place :D
Bring your cb's peeps... Don't want to be telling bad jokes to the ether..
Besides, with cb's we can pretend we're startroopers
PEW PEW!!
FKN LOL :P
    • That'd be right ~ the early RE5R01A is pretty much the same as the RE4R01A in many ways ; problem is they made lots more 4-speeds than 5-speeds.... I'm in AU, so you'll need apply the US supply scene... https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/Mazda/RE5R01A/#scroll-electrical_components This'll give you the aftermarket parts listings -- you're looking for #56712 & #56713
    • Haven't received that part yet, but seeing as you mentioned it I do have some aluminium foil somewhere.... it'll be good for a laugh
    • At a guess being carb all the dash loom will be different & will probably need more work there or replaced.
    • yes easily doable was very common conversion around 15+ years ago Require: Sr20 cross member and engine mounts sr20 gearbox or bell housing if manual CA already sr20 loom and ecu sr20 radiator (or make a cross over pipe to us CA style radiator) sr20 engine All parts can be sourced from an s13 Will require some mods to engine loom to body loom plugs but plenty of info out there on that.
    • Also check the factory 2 wire coolant sensor is functioning properly and plugged in. Ignore the dash, the dash uses a different temp sensor.
