take it out. done.
The rest of us fly by the seat of our pants, or we be smart about how we modify our cars. Like not having the boost solenoid with a big "BLITZ" or whatever sticker on it in full view.
Be smart about how you modify your car, be smart about where and how you drive.
https://www.sau.com.au/forums/topic/262947-need-help/#findComment-4502696
My car is basically a stockie except i have a boost controller installed. I want to know what i can do about it as it is illegal and i can get defected. I see people driving around with Power FCs, what do you guys do to keep your cars undefected?
if u can get a qualified shop to look it over and give u a inspection receipt it wont help the law giving u trouble as mods are illegal by law,but depending on the officer at time and yor attitude,a receipt to show its been installed properly and works safe maybe the difference between a warning or a defect. Also drive like a nutcase and expect to ask for trouble,drive safe and keeps mods to reasonable level done properly and u should be able to enjoy yor car for a long time,in theory that is
https://www.sau.com.au/forums/topic/262947-need-help/#findComment-4502732
Good question.
I have a 32 gtr. IMHO it looks good enough that it doesnt need bodykit. Bodykit is sure to get the authorities attention
So are flashy rims. I still run stock gtr 16" rims...
Over time I've been removing the more offensive modifications or making them legal
For example, I had a big dash mount boost gauge that I removed and placed a smaller one in a safe position - This being because gauges which are mounted on places that one might hit their noggin are a no-no
I had a boost controller which I re-located to the glovebox to avoid detection, but I removed it as the turbos I get will be mechanically set to vent at the right pressure (and the ECU is getting an upgrade...)
I still run the stock ECU.... regardless of what people say, there is a huge potential is recalibrating the stock ECU or getting an add-on board (Such as nistune sell) that I intend on upgrading to later.
I do have pod filters and an aftermarket exhaust. My exhaust is quiet enough to be legal upon the noise restrictions, and since the car was imported under the 15 year rule and not SEIVS (being an '89) it is exempt from the 90+ EPA rules. That said, it still has a cat, a resonator and two JunBL mufflers. And the pod filters are bolted to the chassis so they don't fly around.
I have coilovers - theyre not adjustible however the ride height is 10mm under legal height. I'll be getting some 1cm spacers to get it legal in the meantime, until I can afford sydneykids street suspension kit (totally legal).
I have an N1 water pump, racing hose, aftermarket radiator. If anyone tries to defect me over this, I'll lmfao.
I have a tint too, but its 100% legal.
Apart from that, there are no engineering modifications. I've spent a bit of coin on getting blue LED's, a nice healthy stereo and a couple aftermarket gauges, but theyre located on the front dash behind the steering wheel (so I'd be hitting my head on a steering wheel rather than any gauges)....
Thing is, defectable offences are indifferent to safety. I could get adjustible castor rods to improve the stability of the vehicle, and yet this would be deemed as defectable since its a critical component of the car which isnt stock standard. Theres the argument of using adjustible castor bushes but the degree of adjustibility is limited, and theres no saying that regency wouldnt crust you for that...
ECU's like powerFC's are amusing to me. If you have an ECU, its installed behind the interior kick panel. Theres NO WAY you're going to get defected for an ECU unless you have a powerFC hand controller thats visible.
From the sounds of it, its just your boost controller which is the issue. Be greatful. You can drive around with it for a while until the cops bust you. When that happens, simply remove the boost controller and go to regency - provided nothing else is modified, you'll pass without a hitch...
-D
https://www.sau.com.au/forums/topic/262947-need-help/#findComment-4502897
has anyone had been defected for boost controller?
Yep i have been...well i still am technically
got defected for it....removed it....got the cop shop to sign it off so that i can still drive it around ie tomorrow going to the show etc
https://www.sau.com.au/forums/topic/262947-need-help/#findComment-4502911
Good question.
-D
Thanks man. I surely will remove it. Cheers for the thought!
https://www.sau.com.au/forums/topic/262947-need-help/#findComment-4503664
  • 4 weeks later...
i wouldnt worry about the boost controler mate, there are people put there like me with a few more mods.. ones that cost money to remove/fix.
my turbo timer is hidden, park the car were it isnt as visible, and wait in the car until the car turns itself off..
ive got a boost controller but its unnattached, and its staying that way, haha
https://www.sau.com.au/forums/topic/262947-need-help/#findComment-4559621
probably..... its heading that way.....
Terry,
The boost controller is in plain view, plus the solenoid is mounted just behind the air filter on the suspension tower....
Edited by Mr Sniper911
https://www.sau.com.au/forums/topic/262947-need-help/#findComment-4564266
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
