Hey I gotta rolled R33 with all the good stuff gone lol. If anyone needs annoying interiour crap pwr window motors switches etc PM me.
I will get a better list up soon and sum pics but this is what is available so far:
-Standard shocks with ultra low king springs - $120
-Manual conversion stuff (tailshaft, clutch master lines slave, clutch & break peddle box - $150
-ABS stuff $$$ offers?
-Air bag stuff $$$ offers?
-The boot is the only undammaged panel and has a GTR lookn wing - $150
-AC system is still intact $$$ offers?
-Drivers side S2 headlight - $350
https://www.sau.com.au/forums/topic/262977-wreaking-rolled-r33-s2/
Hi mate, I'm after a front left hub if you still have them and they are alright
Cheers
Tim
Nar soz front crossmember, rear cradle, breaks n hubs all gone.
hey mate got an engine xmember and/or radiator ? if so ... where u at and how much ..delivered to 4207?
Soz dude Rad died in roll and xmember is gone.
Hey chief, how much you want for the set of front and rear brakes,
oh and maybe the brake master cylinder.
Breaks are gone soz. Break master - $50
Series 1 or 2?
Have u got Rear SKYLINE garnish? If Series 2 what colour?
Cheers
Its a series 2, white in colour. by the rear garnish do u mean where is says skyline on the boot?
Oh and can anyone give me a heads up on how to edit and update my first post? there's no edit tab wtf lol soz for the newbie q's havnt used SAU for a while. cheers.
Edited by Driftin~Davo
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
    • Throws on the FS5R30A in most Nissans of this era are actually quite short and direct compared to any remotely modern BMW with the S6-53 transmission. Those things have throws a mile long with rubbery vague everything. Synchro issues combined with a short shifter is just going to break everything even faster.
    • Only thing I'd add...is on recommendation from a good diff shop, I've used mineral oil in my diff including the race car for years. The synthetics can be too slippery and glaze the gears
