Hello, i just have a quick question.... Im looking at buying an in car tv screen, not a name brand. This will be to run the ps2. But, how do you connect the audio from the ps2 into the rest of the system? I have the double din alpine md headunit. Im assuming the video goes straight into the tv screen.. How would it be set up for powerup etc? Like, when the ps2 is powered up, the screen is only powered up at the time? Also, because i have a double din HU, where would be a good spot to mount the screen?
Thanks a million guys.
make an install pod into ur glovebox or something, nice and safe there.
If ur HU doesnt have an aux in, then ur gonna have to use rca splitters or something, and connect the audio to ur amp while ur head unit speakers r connected to ur amp.
that way the ps2's signals r going to amp aswell as HU signals, then u can use whichever one u want at different times.
if it has aux in, then get a converter that converts from RCA to audio in kinda plug and plug it in there.
ur HU will know when the PS2 is on, because there'll be an AUX in signal coming to it.
there should be a power button ur monitor...otherwise it'd be on always.
if thats the case, then u'll have to build a circuit to make it power on when the ps2 is only on, this'd be difficult..i dont know how...maybe ask at Jaycar or something.
with the ainet in you can buy the cable to set it up as aaux in. QAudio should have it.
in regards to screen placement not above the topof the dash.
if you need a few ideas on the ps2 setup email me.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
